03-25-2007 06:24 PM - edited 03-18-2019 07:08 PM
I have some doubts to configure a Unity with FailOver.
I used the Dynamic Configurator and I got the following PartNumers:
UNITY-BUNDLE
UNITY-4.X
UNITY-IP
UNITY-EXCHANGE
UNITY-DS-ENG
UNITY-MS-ENG
UNITY4.X-SL-32
UNITY-UM-USR-E
UNITY-LIC-POOL
UNITY-FOSVR-17-32
MCS-7835-I2-ECS1
UNITY-WIN2K-ENG
UNITY-PWR-ITAL
Do I have to include the UNITYUM-FOVR-USR part number whit the same quantity of UM license that I Ordered?
03-26-2007 10:17 AM
For ever UM license in your failover cluster, you have to have 1 failover license per UM subscriber. (if you want it work correctly)
make sense?
03-26-2007 10:20 AM
Thanks for your repply.
My doubts was becouse I couldnt find the UNITYUM-FOVR-USR partnumber when I used de Dynamic Config to get the configuration
05-03-2007 11:03 AM
I am running into the same problem..I have a brand new install for Unity w/failover..I use the configurator and no where does it have the unity failover user part. it has the unity server failover.
now if I go to the lic upgrades it is there under legacy failover server options. I dont get it
05-03-2007 11:11 AM
There is a license for the failover server itself, then each subscriber needs a failover license.
These get loaded into the primary server, the you run Failover Wizard. Wizard will replicate the databases AND license. When primary goes out, license are and control are trasferred to failover.
Make sense?
05-03-2007 11:19 AM
