Unity Installation
karen.howard
I am installing Unity for the first time in my network test facility. I am using the platform configuration disk (HP) and receive the option to configure the array by pressing F1 or load the OS by pressing F2. I am receiving errors no matter which option I choose. The array configuration reports that there are no controllers available. I have two MCS 7825 systems and receive the same errors on each. Is there a different disk that should be used? I also tried using The IP Telephony Server OS Hardware Detection disk, but that just puts my server in a continuous reboot. What am I doing wrong??
Karen
Hin Lee
I think the hardware platform that you are using is not compatible with the CDs that you have. If you have windows 2000 server disks, you can bring up the OS that way. You will then be able to proceed.
