Unity Integration/Networking
w_basheer
Dears;
I have already Exchange/AD/CCM running environment.
What is the best scenario to install a new Unity Failover clusters?
should i do it directly on the live environment or do a test lab then move the Unity to the live?
Tommer Catlin
If you are simply adding in failover server, just install the server as recommended into the domain, install Unity, windows os, patches, everything same as your production Unity and run failover wizard. First on Prim, then on Sec.
Dear;
I need to install a new Unity.
I dnt have any current unity running.
The question for you is do you want voice mail only or unified messaging?
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/index.htm
rlp
