Unity to Unity Connection Migration
brandon.w
   We are performing a unity 5 to Unity Connection 8.6 migration. Can I verify which CORBAS Import tool is to be used below?
1) COBRAS Import for Connection 7.x and later, version 1.2.13
2) COBRAS Import for Unity, version 1.1.32
Jaime Valencia
www.ciscounitytools.com has a table which lists compatibility between tools and Unity/CUC versions
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
when I read the description for Unity Import, it seemed to imply that this can be used for UC 8.x import from any Unity export.
However, when I am watching the video for UC import, it seemed to say the Connection 7.x can be used for import.
Thus, I got confused and wish to have a confirm answer.
As the name indicates one is for Unity Connection and the other is for Unity. So, when you are migrating from Unity to Unity Connection, you use Unity Export tool and Unity Connection Import.
HTH,
Chris
