VCS changing to expressway
Paul Austin
Level 4
Level 4
I have a pair of CS1000's that I have applied the option key to. The VCSE has changed its description to EXP-E but the VCS-C has stayed the same. Cisco licensing have informed me that it is correct but I am not so sure it is.
Can someone confirm that the description should be EXP-C rather than VCS-C?
Paul
Jaime Valencia
Yes, the description on the top of the page should change to expressway C/E if the licenses are the right ones.
java
if this helps, please rate
