VG224 SIP Configuration Example
chuck47172
Can someone show me a SIP config example for a VG224?
I get an "invalid input detected" error when trying to enter  commands...
bind control source-interface BVI1.
This works on a VG350.
I'm running Cisco IOS Software, vg224 Software (vg224-I6K9S-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Any ideas?
never mind, i figured out I can bind to loopback.
chuck47172
Also note the VG224 I'm working on is in production using MGCP. I plan to run both MGCP and SIP.
I was looking at VG350 that's using SIP to compare to the VG224 that I'm working on and noticed that the VG350 has an "interface BVI1" defined with an IP address of the VG. Not having this configured on the VG224, I'm assuming this is why I'm getting an error when trying to enter the command "bind control source-interface BVI1".
Question is at this point, if I create the BVI1 interface, will it be service affecting to the MGCP that's currently in use on the VG?
