Visual Voicemail - jad midlet not found
ronaldo.gama
I have an implementation of Visual Voicemail on Unity Connection 8.5/CUCM 8.5.
When I try to access the page http:// <IP Unity Conection> / midlets / VisualVoicemail / VisualVoicemail.jad, I get the response file not found.
What´s wrong?
Ronaldo Gama
5 Replies 5
Lucas Vieira
I have exaclty the same problem.
Someone can answer??
I entered on the phone logs, and It says:
Install exception: Missing suit name and a lot more things.
I do not know if it helps (my unity Connection version is 8.6) but I have tried with http://Unity_Connection_IP_Address/midlets/RT/VisualVoicemail.jad and it worked.
mikeduffy13
Make sure you don't have a space in your service name.  ie: Visual Voicemail instead of VisualVoicemail.  There cannot be a space.
Lucas Vieira
Ronaldo,
On all fields of the configuration, you have to put the Hostname of the Unity, not the IP address.
This resolved for me!
mislam
I made it working.
Service Name = VisualVoicemail
ASCII Service Name=VisualVoicemail
Service URL=http:///midlets/VisualVoicemail/VisualVoicemail.jad
Service category = Jave midlet
Service type = Messages
Service Provide=cisco
check = enable
Remember that there should not be any space in service Name.
Check that Service URL is working using the above URL in browser. If you see download pop-up, then the url is correct.
