Voice mail and Embedded-Service-Engine0/0 issue
ammar taha
Recently I added PSTN and SCUE-ISM-8.6-K9 to be applay (IVR and Voicemail) on my Cisco Router 2921 ,
The PSTN now is working properly ,But I facing three issue of the voicemail ,Embedded-service Engine and IVR configuration as the following:
1- I recieved the following error message when enable the  Embedded-Service-Engine0/0
"Memory size does not meet the requirements of Embedded-Service-Engine0/0"
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FCZ162670HW
4 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.6.6 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
2- Kindly the attached file of the Voice mail configuration but not working.
3- Please, can you provide of a document about IVR configuration ?
Hello Ammar,
As per the error you required more memory for ESE module to work, you have only 512MB memory. Now I assuem you configured on Service-Module right ? It will work fine without any issue.
Next for your voicemail not working can verify that you have configured the SIP dial-peer to reach the Voicemail tiggered phonenumber i.e. 700 in your case.
dial-peer voice 101 voip
session protocol sipv2
session target ipv4:192.168.130.101
destination-pattern 700
Selva
Hi Selva,
Thanks, It's working now,
Please, can you provid me for IVR configuration, how I can download a file for IVR to be store in my flash?
Many thanks
