09-09-2011 10:39 AM - edited 03-19-2019 03:34 AM
Hi im having a very strange problem witch the voice mail ports between a CM 8.5 and a Cisco Unity connection 8.5 , i configured them and they registered and all was working fine, however when i rebooted the servers the ports stayed in status unknown i tried resetting them both sides, re adding config both sides and nothing after hours of trying and deleting and adding the same config it worked again, however we have a power outage today and the same thing happened again status unknown and still i cannot get them to register again. Any ideas or help would be appreciated.
09-09-2011 12:35 PM
I'm not sure but it could be a DNS issue. Is DNS configured or are you just using IP addresses? Make sure everything is resolving correctly.
09-09-2011 03:47 PM
All is configured with ip addresses , its really weird after 3 hours they registered again... but if i reboot them same problem will happen
