what is the best cisco ip phone for call manager and ipcc practicals
khannanaval
                   Hi i have recently started my training on Cisco Call Manger and CCIE voice from a leading cisco voice training institute (http://networkerszone.com/), and am working on 7900 series phones, is there any other phone that i should use or this is fine.
ronpatel
Level 8
Level 8
For CCIE 79XX phones are ok. You can also use Soft phone for your practice. Use latest generation ip phones for practice, This will help you in + dialing and normalisation practice.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Gajanan Pande
Naval,
7900 phones are good enough for both CUCM & UCCE. UCCE however doesnt support all models of 7900 series, please refer UCCE Compatibility Matrix for supported phone models.
You may also use CIPC as agent phone.
GP.
Pls rate the post if it helps !!
