CDR (Call Detail Record) problems
admin_2
Level 3
Level 3
Hello there,
I am having a few problems running CDR on a CUCM 6.1 server.
So here goes:
1. First of all, in the Disaster Recovery System, when I try to perform a manual backup of the system, in the Select Features section I do not see the CDR_CAR option, even dough CDR is configured correctly for this server.
2. Secondly, in the CDR Errors report, I get lots of errors. I cannot figure out why this happens. Here's a listing:
Error Description % of each Error
destLegIdentifier in a CDR record is not a positive integer. 0.07
dateTimeConnect in a CDR record is not a positive integer. 77.23
destDeviceName in a CDR record is null. 22.68
origDeviceName in a CDR record is null.
0.02
3. Lastly, in the System Overview, Gateway Summary report, I only see 2 gateways listed, even dough I have four of them in my network (configured as H323 gateways in the call manager). Is this a problem? And if so, how can it be solved?
I would really appreciate any tip regarding my problems.
Thanks in advance,
Alexandru Mocanu
wong34539
Level 6
Level 6
testeven
Hi!
This is for issue #1:
In newer CUCM versions, when you do a DRF backup and select the CCMDB component (the only one listed), the CDR/CAR DB is include in there.
If you go to the CCM CLI and do the following:
file list activelog /platform/drf/log/
Then do a file view activelog /platform/drf/log/
If you check the CCMDB backup file and you will see that CDR data was backed up.
HTH! If it does, please rate :)
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Not applicable
Salut
Din ce vad ai reusit sa configurezi CDR-ul sa mearga.
Eu am o problema si mai ciudata cu CUCM 6.1
Nu reusesc sa il fac sa scrie ceva in baza de date. Nu are nici o inregistrare.
Cum ai configurat CUCM sa verse inregistrari?
testeven
Can you translate that to English please? :)
