12-12-2020 05:55 AM
my system is cucm 8.6.2 -s,ip to cisco 3925 router to sip to telco
I couln't call iphone to outside but ı can ringing outside to iphone but couldn't call
ı added configuration and ccsip inout debug at the attached
12-14-2020 05:30 AM - edited 12-14-2020 05:31 AM
Could you elaborate on the call flow? Maybe something like this? Phone <-> CCM <-> SIP Trunk <-> 3925 <-> PRI <-> carrier
Then provide an idea of what calls are failing and in what direction?
I would also recommend you consider another set of dial-peers.
dial-peer voice 1001 voip
description *** OUT PG ***
destination-pattern 05.........
session protocol sipv2
session target ipv4:213.254.158.116
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 1002 voip
translation-profile outgoing CUCM
destination-pattern 08505281...
session target ipv4:10.29.147.5
voice-class codec 1
dtmf-relay rtp-nte
_________________________
The red text indicates potential issue that could cause a loop. You can limit this with the ^ and $ to note the start and end of a digit string but will only ever match the exact digit count between the two characters. You may want to consider incoming uri and steering codes.
12-14-2020 10:46 AM
Hi Nathan;
not pri
CUCM-SIP TRUNK - Cisco 3926 - SIP TRUNK -TELCO
Ourproblem is when we try to call iphone to outsite no call enable.but outside to iphone we see timer callaing.iphone hear outside voice but outside couldn't hear iphone voice
