ā07-28-2021 12:42 AM
hello
When i try to add my gateway to cucm V 10.5 i just have two option MGCP And SCCP i dont see h323 could you please assist me to fix this
thank you
Solved! Go to Solution.
ā07-28-2021 12:52 AM
Dont select the router model, if you select model will see option MGCP or SCCP. In the add gateway drop down you can see the H323.
See the below image.
ā07-28-2021 01:02 AM
thank you for help
