Extension is not a valid entry
William Hoover
We have some extensions that you cannot connect to from outside calls. When a outside call comes in and the caller tries to connect to certain extensions they get a message that the extension is not a valid entry. I do know that the extensions that get this error do not have voice mail enabled. Is a voice mail box required for an outside call to be routed to an internal DN? How can I allow calls to be routed to these DNs without a voice mail box?
Thanks!
Bill
3 Accepted Solutions
Brad Magnani
Hi Bill,
This is configurable on the Call Handler greetings page:
Hope that helps,
Brad
Rob Huffman
Hi Bill,
I'll just add a link to the great info from Brad and Java (+5 each my friends!)
You'll want to look at the system transfers and system transfer restriction table
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag115.html
Cheers!
Rob
Correct, or just uncheck row #4 that has the * listed to test, but that could be a security risk if you leave it that way for any period of time.
Brad
29 Replies 29
Jaime Valencia
Assuming you're talking about Unity because you don't mention what VM system you have, yes.
Unity only recognizes as valid entries DNs that are already configured in something (Subscriber, call handler, etc).
Use a call system transfer if you need to transfer to non-vm users.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Brad Magnani
Hi Bill,
Hope that helps,
Brad
Thanks Brad, well that got me past the initial error. Now I get "You cannot be transferred to this number"
Rob Huffman
Hi Bill,
Cheers!
Rob
Confused by the directions, so I need to add the the first number of each DN followed by "???"  like "2???", "3???", "4??? ect and make sure "Blocked" is not checked? And do they need to be at the bottom of the list or at the top?
Here is the current config..
Thanks again!
Bill
Brad
Rob to the rescue, +5!
You guys ROCK!! Thanks Rob and Brad that worked!
OK so its not working again. Yesterday it seemed to be working fine although I did not test from an internal line. After following your suggestions I got it to ring to the extension and I tested a few others that did not have Unity users (VM) and they worked fine too. As of some time between now and then when you call the main line from outside and then enter the extension it says "You cannot be transferred to this number, please check the number and try again". If I cdial the 4 digit extension from an internal line it puts me right into the Unity system, if I then try the extension again I get the same message "You cannot be transferred to this number, please check the number and try again".
Here is my line restrictions table.
Here is my Greeting config for my main (I assume) line
Any suggestions?
Thanks again!
Hi Bill,
The reason why it's failing is because you've got * set to be blocked, which is stating block everything.  * = all patterns  You can define as many patterns as you want but as long as * is blocked, nothing will work.  The default rules do a pretty good job of covering the common #'s you don't want users dialing.  There of course may be more specific patterns that you may want limited, but eventually the * needs to be unchecked - probably once you've defined all of the patterns you want blocked.
Brad
I thought by defining those patterns that I want to be unblocked this would allow them even though all other patterns are blocked by the * in pattern 12. So I should not block all other patterns other than the ones I have defined as blocked? So if I unblock all by using * then I don't even need to define the other unblocked patterns in have in 1 - 5 and pattern 7?
Thanks!
Bill
Adding to that I am pretty sure I never had * unblocked yesterday when it was working, but I could be wrong and you (Brad) even said before that unblocking all is a security risk in a previous post. I just want to make sure I don't screw up
Keeping it unblocked can be a risk if you don't specify rules granular enough for your environment that you may not want being dialed, but I had just recommended doing it for testing purposes.  Rob is correct, the rules are matched top down, first match wins.
Really its just making sure no one can dial in and use our system to call out right?
