Lync Conference Calls Dropped after 59 min 28 seconds - Direct Sip
Rws872222
We have a direct sip trunk to our cisco call manager (version 8.6) and we've got dial-in conferencing set up so users can now setup phone conferences using Lync.  I recently started to get reports of phone conferences that would just drop for no reason.  The actual Lync web conference would stay up and continue but anyone dialed in over the phone would get disconnected and the organizer would have to set up the dial-in conference again.  Normal Lync calling to cisco phones works fine, only happens with dial-in conferencing.  I set up my own Lync dial in conference and just let it sit and every time I did so the dial-in conference would drop at exactly 59 min and 28 seconds.  Snooper Lync mediation server logs below.  It looks like this is pointing to something on the Cisco gateway that is terminating the call, something other than Lync.  I am correct in assuming this?  Has anyone come across this before?
Start-Line: GatewayCall SignalingState is disconnected, reason is: TerminatedRemotelyDirection: Inbound
Start-Line: GatewayMedia's InnerDispose was called with shutdown = True. Direction: Inbound
Start-Line: Terminating Proxy side call with session state: Connected, sip-response: 200, ms-diag: 10027, ms-diag reason: Normal termination response from gateway after the call was established.
fb_webuser
Level 6
Level 6
Checking the issue..TA
Posted by WebUser Saikrishna Kalakonda from Cisco Support Community App
This resolved this issue.  One of our telecom guys had to run these commands on the CUBE that lync connects to:
voice class sip-profiles 100
request INVITE sip-header Allow-Header modify " UPDATE, " " "
  request REINVITE sip-header Allow-Header modify " UPDATE, " " "
  response 200 sip-header Allow-Header modify " UPDATE, " " "
  response 180 sip-header Allow-Header modify " UPDATE, " " "
voice service
sip
   sip-profiles 100
