Missed calls not accessible on ip phone 6945
akram.root
Level 4
Level 4
Hello all,
I had installed a CME , registred with ip phones 6945, and 7962.
the problem is i have not accessible on missed calls on ip phone 6945.
you can find attached the configuration of CME.
can you help me please .
Best regards
Akram
Leonardo Santana
The issue happens only with 6945 phones? Is one or all of this type of phone?
Try a firmware upgrade or a factory reset.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
thank you for your reply
yes just not display for ip phone 6945
Best regards
