Can you please tell us the part codes to be used for migrating unity connection 2.x/7.x users to 9.1.
I have read the Cisco ordering guide and tried to configure the same in CCW, however the part codes and their descriptions are different and leading to confusion.
Table 7. Version Upgrade User Product Part Number Option
Product Number | Description | List Price ($US) |
UNITYCN9-USR-VUP | Migration from Unity 4.x or later/Cxn 1.x or later to Unity Cxn 9.x – Users | $38 |
MIG-UCXN9-USR | Migration from Unity 4.x or later/Cxn 1.x or later to Cxn 9.x with UCSS purchase | $9 |
MIG-UCXN9-ENH-USR | Migration from Unity 4.x/Cxn 1.x or later to Cxn 9.x Enh with UCSS purchase | $44 |
In CCW:
UNITYCN9-VUP-USR Upg Unity Cxn 2.x or later to Unity Cxn 9.x Users $ 38.00
MIG-UCXN9-USR Mig Unity 4.x or later/Unity Cxn 1.x to Unity Cxn 9.x Users $ 15.00
MIG-UCXN9-ENH-USR One Unity Connection 9.x Bas to Enh Upgrade User $ 44.00
It would be great, if i am advised
1. which part code to select for older unity connection 2.x/7.x users to basic licensing in 9.1
2. which part code to select for older unity connection 2.x/7.x users to enhanced licensing in 9.1
Appreciate your support and thanks in advance.
Can anyone please throw some light on this.....
You can reach pre-sales and they can assist you with getting the right PNs for this.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
