Need clarity on part codes for unity connection users
yiqinc2004
Can you please tell us the part codes to be used for migrating unity connection 2.x/7.x users to 9.1.
I have read the Cisco ordering guide and tried to configure the same in CCW, however the part codes and their descriptions are different and leading to confusion.
In Cisco Ordering Guide:
Table 7. Version Upgrade User Product Part Number Option
Product Number
Description
List Price ($US)
UNITYCN9-USR-VUP
Migration from Unity 4.x or later/Cxn 1.x or later to Unity Cxn 9.x – Users
$38
MIG-UCXN9-USR
Migration from Unity 4.x or later/Cxn 1.x or later to Cxn 9.x with UCSS purchase
$9
MIG-UCXN9-ENH-USR
Migration from Unity 4.x/Cxn 1.x or later to Cxn 9.x Enh with UCSS purchase
$44
In CCW:
UNITYCN9-VUP-USR               Upg Unity Cxn 2.x or later to Unity Cxn 9.x Users        $ 38.00
MIG-UCXN9-USR                     Mig Unity 4.x or later/Unity Cxn 1.x to Unity Cxn 9.x Users                                                             $ 15.00
MIG-UCXN9-ENH-USR             One Unity Connection 9.x Bas to Enh Upgrade User        $ 44.00
It would be great, if i am advised
1. which part code to select for older unity connection 2.x/7.x users to basic licensing in 9.1
2. which part code to select for older unity connection 2.x/7.x users to enhanced licensing in 9.1
Appreciate your support and thanks in advance.
yiqinc2004
Can anyone please throw some light on this.....
You can reach pre-sales and they can assist you with getting the right PNs for this.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
