Problem with Insert Gateway in Bulk administration - error 407 - CUCM
Hi guys,
i have a problem while inserting a gateway from bulk administration. I have already configured around 3-4 VG310, so i had already created a template.
Today i tried to import another one gateway, but as job result i had:
Insert Gateways
Failure Details :
Domain Name Error Code Error Description
407 The Model type for the specified Product type was not found
Result Summary :
INSERT for 0 Gateway passed.
INSERT for 1 Gateway failed.
And that's the file i had tried to insert (.csv):
DOMAIN NAME,DESCRIPTION,SLOT,SUBUNIT,PORT DIRECTORY NUMBER,PORT NUMBER,PORT DESCRIPTION,DEVICE POOL,COMMON DEVICE CONFIGURATION,LOCATION,ALERTING NAME  1,DISPLAY  1,LINE DESCRIPTION  1
SKIGWEBD5B93A69,VGFAX,0,0,963491,0,FAX,fax-DP,CDC,FAX-L,FAX,FAX,FAX
To complete my info, i work with a CUCM 11.X and the VG310 is SCCP connected. i also read tht page:
https://www.cisco.com/c/en/us/support/docs/unified-communications/bulk-administration-tool/118882-config-vg-00.html
thank you in advance :)
0 Replies 0
