Setting up CUCME PSTN connection via POTS
Chris Campbell
Hello all,
I am trying to learn CUCME.  I have some test equipment consisting of two 7821 SIP phones, a 2951-VSEC router, a VIC2-4FXO card, and a PVDM32 DSP module.  I have gone through some tutorials and have the ability to call from one 7821 to the other.  I am now trying to figure out how to make a connection to the PSTN.
To accomplish my PSTN connection, I called up the phone company and asked to add home phone (POTS) to my service.  Previously I only had DSL.  The POTS service is supposed to be active.
When I try a test outbound call using the command
csim start 2945237
The FXO card port 0 light comes on for less than a second, and then turns off.  Trying to call from one of the 7821 phones gets me a fast busy signal.
I do have a POTS phone somewhere in a box, but I'm not sure where it is at this time.  Obviously I'd like to verify the POTS connection is working, but I have to find my analog phone before I can do that.  What else can I do from the 2951 router to test to make sure the line is active?
Here's what I have:
dial-peer voice 1 pots
 description local
 destination-pattern 2......
 no digit-strip
 port 0/1/0
 forward-digits 7
voice-port 0/1/0
 connection plar opx 4001
______________
#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
PWR FAILOVER PORT        PSTN FAILOVER PORT
#csim start 2945237
csim: Test started.This command can only be run one at a time.
csim: called number = 2945237, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(1024) minor(0x0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
*Apr  3 17:30:35.718: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2945237, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2945237
*Apr  3 17:30:35.718: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=2945237, Expanded String=2945237, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Apr  3 17:30:35.722: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=1 Is Matched (1 digits)
*Apr  3 17:30:35.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
*Apr  3 17:30:35.722: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Apr  3 17:30:35.722: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
#show voice port 0/1/0
Foreign Exchange Office 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
 Type of VoicePort is FXO
 Operation State is DORMANT
 Administrative State is UP
 The Last Interface Down Failure Cause is Administrative Shutdown
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 3 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 128 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is plar opx
 Connection Number is 4001
 Initial Time Out is set to 15 s
 Interdigit Time Out is set to 10 s
 Call Disconnect Time Out is set to 60 s
 Power Denial Disconnect Time Out is set to 1000 ms
 Ringing Time Out is set to 180 s
 Wait Release Time Out is set to 30 s
 Companding Type is u-law
 Region Tone is set for US
 Analog Info Follows:
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 0
 Impedance is set to 600r Ohm
 Station name None, Station number None
 Translation profile (Incoming):
 Translation profile (Outgoing):
 lpcor (Incoming):
 lpcor (Outgoing):
 Voice card specific Info Follows:
 Signal Type is loopStart
 Battery-Reversal is enabled
 Number Of Rings is set to 1
 Supervisory Disconnect is signal
 Answer Supervision is inactive
 Hook Status is On Hook
 Ring Detect Status is inactive
 Ring Ground Status is inactive
 Tip Ground Status is inactive
 Dial Out Type is dtmf
 Digit Duration Timing is set to 100 ms
 InterDigit Duration Timing is set to 100 ms
 Pulse Rate Timing is set to 10 pulses/second
 InterDigit Pulse Duration Timing is set to 750 ms
 Percent Break of Pulse is 60 percent
 GuardOut timer is 2000 ms
 Minimum ring duration timer is 125 ms
 Hookflash-in Timing is set to 600 ms
 Hookflash-out Timing is set to 400 ms
 Supervisory Disconnect Timing (loopStart only) is set to 350 ms
 OPX Ring Wait Timing is set to 6000 ms
 Secondary dialtone is disabled
7 Replies 7
Chris Campbell
Here's an update.  I got a call from the phone company tech and he said sales screwed up my order, so the POTS service isn't connected.  I also found my analog phone and verified that there's no service.  So that explains it.  Hopefully they will straighten out some of this next week.
Just a suggestion because I find analogue PSTN lines a pain nowadays.  See if you can find a SIP service to sign up to, and get your 2921 to register with that for your external calls.  Be careful with security, but if you use one of the pre-paid services even the worst sort of dial through fraud can only consume the credit you've already paid for.
By the way don't think that toll fraud is limited to IP services.  I knew a company where they had analogue lines connected to a router, which was also an Internet gateway.  A fraudster managed to access the router and ran up huge bills making calls on the analogue lines.
I really appreciate the warning about toll fraud.  Right now, this router is behind my another router which is configured as a firewall, and I do a good job of security, so I think I'm okay, but it is something to watch for.
I got the phone company to straighten out my order and after that, everything is working fine.
In the meantime, I am trying to figure out why the system doesn't complete a call when I pick up the receiver and dial the number, but if I punch it in with the buttons and press the call button, it works fine.  That applies to calls inside my house, and calls outgoing to the PSTN.  Any ideas?
That could be an overlap in your dial plan.  When you say it doesn't work dialling off hook, do you mean it comes up with an error before you've finished dialling?  If so then note exactly what digits you've dialled, and look for some match for those digits.
It doesn't give me any errors at all... it just hangs there with dead air and doesn't complete the call.
I think I'm onto something after printing out some debugging information.  It's saying the called number is 4 and more digits are needed.  Yes, that's true.  My test setup used 4-digit extensions in the house.  I'm wondering why it's not seeing the rest of the digits.  I may try setting up extensions that are just one digit and see how that works.  But I'm still not understanding why it's cutting off after a single digit.
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=4001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4(TON=Unknown, NPI=Unknown))
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:1C12228C
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/cc_process_call_setup_ind:
   Event=0x164234E8
*Apr 14 14:36:18.560: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/ccCallSetContext:
   Context=0x177110C4
   >>>>CCAPI handed cid 1128 with tag 40001 to app "_ManagedAppProcess_Default"
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/ccCallSetupAck:
   Call Id=1128
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Apr 14 14:36:18.560: //-1/2316FB8E85B0/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4
*Apr 14 14:36:18.560: //-1/2316FB8E85B0/DPM/dpMatchCore:
   Dial String=4, Expanded String=4, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Apr 14 14:36:18.560: //-1/2316FB8E85B0/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=40001
   Result=1
   Result=Partial Matches(1) after DP_MATCH_DEST
*Apr 14 14:36:18.560: //-1/2316FB8E85B0/DPM/dpMatchSafModulePlugin:
   dialstring=4, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
*Apr 14 14:36:18.560: //-1/2316FB8E85B0/DPM/dpMatchPeersMoreArg:
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Apr 14 14:36:18.560: //1128/2316FB8E85B0/CCAPI/ccCallReportDigits:
   (callID=0x468, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=1128
*Apr 14 14:36:18.560: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_S
I changed the dn of the other phone to 4 and it works like I expect.  Interesting!
