Unity import problem 4.01
OliP.
I've deleted a unity subscriber and try to import him back again. I receive a 0x80070005 error when I try to do it by bulk import exchange (2000). Eventlog says:
AvDSAD-Service could not change Object:
Type: AVOBJECTTYPE_MAILUSER
Name: CN=First Last,CN=Users,DC=XXX,DC=de
Reason: ERROR_ACCESS_DENIED: Access is denied.
...which seems to be a permission error on the account which runs the AvDSAD Service. But I'm able to import other users without problems.
Thanks for support
Oliver
lindborg
Can you try to use the Directory Access Diagnostics (DAD) tool found in the Tools Depot to check that guy? Some of the types of things we see is the user could be in a different container than others so rights are not correct or that user is flagged to not inherit rights from above (the rights Unity needs are granted on the container above them) which can burn you...
