V-CUBE - running on UCS
Forcefield
Just wanted to see if anyone out there may have tried this or if anyone has any recommendations.
I am looking to see if its possible to run Virtual Cube on the same UCS box that hosts CUCM cluster.
Is this a no-can-do or is there a recommended approach to look at? The idea being of course that the Cube will be our Demarc line to the carrier, I'm just not sure if its a good or bad approach to try.
Thank you
FF
Deepak Rawat
Refer below:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Sizing_Guidelines
Deepak
valerie.kan
Level 5
Level 5
I can't say I have done this before, but this link might help you:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-virtual-cube.html
It said that virtual CUBE integrated into the Cisco CSR 1000V routers runs on a hypervisor on the Cisco UCS. It works with the ESXi hypervisors supported by Cisco CSR 1000V Series router and is supported on the a few of the UCS configurations.
