Muhammad Afzal
Overview
Cisco UCS also offers Python SDK which is a set of Python modules, each containing one or more classes, developed specifically to automate UCS Manager.
Or Alternatively, you can simply submit the POST request to Cisco UCS API. The request will contain the XML to perform certain action in UCS Manager.
Let’s start coding and gets our hands dirty. This is a very simple example for writing your own plugin to automate Cisco UCS Manger.
Instruction
Write two python module
  1. my_mechanism.py
  2. my_mech_ucs.py
my_mechanism.py
from neutron.openstack.common import log as logging
from neutron.plugins.ml2 import driver_api as api
from my_mech_ucs import ucs
LOG = logging.getLogger(__name__)
class MyDriver(api.MechanismDriver):
   def initialize(self):
       pass
   def create_network_postcommit(self, context):
       segments = context.network_segments
       vlan_id = segments[0]['segmentation_id']
       LOG.debug("creating vlan_id=%s",vlan_id)
       ucsm = ucs()
       token=ucsm.GetAuthCookie()
       LOG.debug("UCSM Auth Cookie=%s",token)
       ucsm.ProvisionVLAN(token,vlan_id)
       ucsm.UCSLogout(token)
   def delete_network_postcommit(self, context):
       LOG.debug("This is from my plugin Afzal....")
       LOG.debug("deleting vlan_id=%s",vlan_id)
       ucsm = ucs()
       ucsm.DeProvisionVLAN(token,vlan_id)
my_mech_ucs.py
import urllib2
from xml.dom import minidom
class ucs():
    ip = "http://<ucsm ip address>/nuova"
    def GetAuthCookie(self):
            outcookie="nocookie"
                   Authdata= "<aaaLogin inName='config' inPassword='config'></aaaLogin>"
                   request = urllib2.Request(self.ip, Authdata)
            request.add_header("Content-Type","application/xml")
                   response=urllib2.urlopen(request)
                   xmlout= response.read()
                   xmldoc = minidom.parseString(xmlout)
                   xmlelement = xmldoc.getElementsByTagName("aaaLogin")
                   outcookie = xmlelement[0].attributes['outCookie'].value
                   return outcookie
    def ProvisionVLAN(self, token, vlanid):
            vlanstring = "<configConfMos inHierarchical='false' cookie='" + token + "'><inConfigs><pair key='fabric/lan/net-VLAN" + str(vlanid) + "'><fabricVlan compressionType='included' defaultNet='no' dn='fabric/lan/net-VLAN" + str(vlanid) + "' id='" + str(vlanid) + "' mcastPolicyName='' name='VLAN"+ str(vlanid) +"' pubNwName='' sharing='none' status='created'></fabricVlan></pair></inConfigs></configConfMos>"
                request = urllib2.Request(self.ip, vlanstring)
    def DeProvisionVLAN(self, token, vlanid):
            vlanstring = "<configConfMos inHierarchical='false' cookie='" + token + "'><inConfigs><pair key='fabric/lan/net-VLAN" + str(vlanid) + "'><fabricVlan compressionType='included' defaultNet='no' dn='fabric/lan/net-VLAN" + str(vlanid) + "' id='" + str(vlanid) + "' mcastPolicyName='' name='VLAN"+ str(vlanid) +"' pubNwName='' sharing='none' status='deleted'></fabricVlan></pair></inConfigs></configConfMos>"
    def UCSLogout(self, outcookie):
            strlogout = "<aaaLogout cookie='" + outcookie + "'/>"
            request = urllib2.Request(self.ip, strlogout)
            xmlout=response.read()
Setup Instructions
Some Screen Shots
ml2_conf.ini file
specify mydriver in mechanism_driver section as shown below:
Module file
SELINUX Config
entry point
Module file entry in entry_point.txt. MyDriver is the class name in my_mechanism.py
Debug the module
With the following python code you can verify if the module is working. this would provision VLAN with the ID 20 is Cisco UCS Manager
#Python
>>>x=uss()
>>>y=x.GetAuthCookie()
>>>print y
>>>x.ProvisionVLAN(y,20)
>>>x.UCSLogout(y)
Demo
The following demo show the working plugin.
