6120XP was included in the B series blade drive?
yin liu
As I read hcl, know that windows 2003 can not be installed on the b200m2.
I re-installed 2008 r2 on b200m2
but after the installation,device Manager shows the chipset installed,
And the process did not load LSI sas driver.
This is completely different with rack-mounted servers.
I think it,install the system process, 6120xp distributed drive to b200m2.
the ucs-k9-bundle-b-series2.0.3b.B.bin package inside contains device driver
padramas
What is listed in the screen shot is firmware of LSI 1064E controller on the blades and not the OS drirver.
If you are installing to local hard disk drive on the blades, I am not sure if Windows 2k8 ships with LSI 1064E driver or not.  If not, we need to map the driver ISO and install the driver before proceeding with OS installation.
http://www.cisco.com/en/US/partner/docs/unified_computing/ucs/os-install-guides/windows/BSERIES-WINDOWS_chapter_011.html
Padma
