aaa ldap problem on UCS Manager
dinoantonucci
Hi all,
i'm working on UCS Manager Suite and i would like configure Authentication method using LDAP protocol ( AD : Windows 2008 R2 Standard Edition).
I follow this configuration guide:
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/sample_configurations/UCSM_1_4_LDAP_with_AD/b_Sample_Configuration_LDAP_with_AD.pdf
but i obtained some message : authentication failed.
10.164.85.2 (UCS Manager)
10.164.85.21 (AD)
I have some doubt regarding  "Non-Admin Bind User Account" : what are the privileges that it need?
In attach wireshark capture taken on AD Server.
Regards.
Dino
Brian Morrissey
Hi Dino,
It looks like it is trying to bind using the account "ucs binduser" and no password.  Can you verify a password is set on the bind account in ucs?  The bind account needs only read access to active directory.
scope security
scope ldap
show server
Hi Brian,
this is output as you request:
UCS-DEMO-A /security/ldap # show server
LDAP server:
    Hostname or IP address   DN to search and read    Port  SSL  Password
    10.164.85.21             CN=ucs binduser,OU=DDUsers,DC=didata-dc,DC=local
                                                      389   No
You're right regarding no password set but i configure in "ldap provider menu'" password type.
Can you explain where do I define password for "ucs binduser" ?
Thank you for quick answer.
Dino
Hi Brian,
I deleted ldap provider profle and reconfigure new profile with same parameters and now it works.
I already use "aaa test server" command to verify authentication and it's works BUT if i checks output
scope security
scope ldap
show server
i obtained same output
DAP server:
                                                      389   No
I expected **** under Password column.
Thank you for support.
Regards.
Dino
