08-09-2012
04:04 PM
- last edited on
03-25-2019
01:37 PM
by
ciscomoderator
Hi there guys!
I'm triying to change a blade of chassis, but everytime that we make the change the OS into the blade its deleted; this is hapenning with all the blades that are trying to move. We don't have any Scrub policy applied.
Anyone has idea of what is happening?
08-09-2012 04:07 PM
I assume this is a local boot on the blade?
What is the local disk policy set to?
Is the local disk policy set to "protected" mode?
How are you changing the blade, decom first and then swap or just swap?
Robert
08-09-2012 04:34 PM
Hi robert,
1 and 2 :The local disk polic is raid1 and the protect configuration setting is active.
3: Just swaping the blades into another chassis
08-10-2012 05:42 PM
Before removing a blade always run a decommision, even if you are going to use the same service profile:
Server - General - Server Maintenance.
When you insert it in another slot, it will run a re-acknowldge. If you are going to apply the same service profile with the local disk configuration that you mention, the data should stay there.
If the Protect Configuration box is checked, the server retains the configuration in the local disk configuration policy even if the server is disassociated from the service profile.
When a service profile is disassociated from a server and a new service profile associated, the setting for the Protect Configuration property in the new service profile takes precedence and overwrites the setting in the previous service profile.
Note | If you disassociate the server from a service profile with this option enabled and then associate it with a new service profile that includes a local disk configuration policy with different properties, the server returns a configuration mismatch error and the association fails. |
