B-Series KVM Port Setting
Hello Team,
Is it possible to change the KVM Port for UCS B-Series servers?
I used WireShark to verify that KVM Access for B-Series uses the same default port as UCS C-Series (2068).  I found instructions regarding changing the KVM port for C-Series.  However, I could not find any documentation on changing this value for B-Series.
From the UCS CLI, i tried searching local-mgmt commands as well scoping to the system, fabric interconnects, and individual blade servers, but I still could not find anything.
Thank you,
Trevor
====================================================================================== If my answers have been helpful in any way, please rate accordingly. Check out my blog for useful vSphere & UCS tips: www.vmtrooper.com
Robert Burns
Trevor,
Since the KVM is NAT'd through the management interface of the FIs, we do not allow the port to be changed on B-Series.
Robert
Robert Burns
Trevor,
Robert
Thank you Robert,
That makes sense from the perspective of preventing per-blade changes.
However, if we ever run into customers that insist on changing any and all default ports, will there be a consideration for allowing a system-wide change (perhaps within connect local-mgmt) to change the 2068 value for all blades?
Trevor
Here's a list of externally exsposed ports used in the system:
HTTP—By default, TCP port 80
HTTPS—By default, TCP port 443
FTP—By default, TCP port 21
TFTP—By default, UDP port 69
SSH/SFTP/SCP—By default, TCP port 22
SNMP—By default, UDP port 161. 162
SMTP—By default, TCP port 25
DNS—By default, UDP port 53
IPMI—By default, UDP port 623
SoL—By default, TCP port 22
KVM—By default, TCP port 2068
There may be other internal ports used, but the user will used by the system only.   If this is an important request for your customer I would suggest you go through your local Cisco account team and ask for this feature.  Coming through the account team the request will have more weight.
Robert
