Booting from SAN-SAN Target Paths are not showing
isaac anish
Hi community,
Here i configure in UCS booting from SAN,We created 2 vHBA-1 and vHBA-2
In vHBA-1(PRI)
Primary SAN traget-xx.xx.xx.xx.xx.xx
Secondary SAN target-xx.xx.xx.xx.xx.xx
In vHBA-2(SEC)
So here i am able to see only 2 paths that to also secondary target paths of both vHBA in UCS.And in host windows MPIO that two paths are  showing the Active/unoptimized path.
Here i attached the screen shot also,Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!
16 Replies 16
Marcin Latosiewicz
Isaac,
Check out two things.
Some framework around troubleshooting.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/guide_old_FM/TS_SANBootAndConnect.html
This is probably the best external writeup about lunmap/lunlist commands, which is where you should start.
http://jeffsaidso.com/2012/02/ucs-boot-from-san-troubleshooting-with-the-cisco-vic-part-2/
M.
Walter Dey
Can you please post a picture of the physical setup !
- storage connected via a SAN ? or direct to FI ?
- cabling of SAN switches (or FI) to storage controller ?
Hi walter,
Thanks for the reply,storage
-connected to via FI to SAN switch to netapp storage controller.
-And cabling of SAN is SAN switch to storage controller..
i dont have the  physical connectivity details,Usually how to connect for the active/active controller in netapp....?
And why its not showing the primary path of the 2 vHBA's....?is that mistake in configuration  in UCS end...?
vHBA-2
Controller 1:
50:0a:09:82:80:21:18:54
50:0a:09:82:90:21:18:54
vHBA-1
Controller 2:
50:0a:09:81:80:21:18:54
50:0a:09:81:90:21:18:54
Hi Isaac
I would think it should be wired like this
vhba-1 - SAN-A - Controller -A (primary)
vhba-1 - SAN-A - Controller -B (secondary)
vhba-2 - SAN-B - Controller -B (primary)
vhba-2 - SAN-B - Controller -A (secondary)
Q. did you do the zoning accordingly; 2 zones per fabric !
Walter.
yes we did the zoning accordingly 2 zones per fabric.
Here i attached the lamap screen shot
Why are the node wwn all 0 ? very strange ?
Can you please also post screenshot of "configured boot order" ; I see actual boot order !
Please find the deatils.
Will server is boot from active/unoptimized path...?
Q. did you install a OS ? does your multipath software see 4 paths ?
Seems to me, that the primary path doesn't see the boot lun; this is always the first choice.
Yes i installed OS,and in MPIO also configured but its showing only 2 paths that to also active/unoptimized.its not showing the 4 paths...
So where i need to check in SAN or UCS end....?
How to trouble shoot it...?
Here i attached  the screenshot of MPIO
Hi Isaac
Very clear now: it's not only a boot issue, but also a MPIO issue; you only see 2 paths, not 4 !
You seem to have 2 storage controller A and B, each having 2 ports: A1, A2 and B1, B2
Your boot policy says
vhba 1 - primary path - A1
vhba1 - secondary path - A2
Q. is your cabling from the SAN switch to storage controller done in exactly this way ?
Above should be
vhba 1 - secondary path - B2
If primary and secondary path of vhba 1 go to controller A, it might be, that only one port has control over the lun; therefore you see what you see, namely 2 path, not 4.
Walter.
- See more at: https://supportforums.cisco.com/discussion/12517616/booting-san-san-target-paths-are-not-showing#comment-10530361
Hi Walter,
But in server  bios is detecting only 2 wwpn number then it wiil show only 2 paths in MPIO rit.
so were i need to check weather UCS or SAN end.
Here i attached bios screen shot.
Hi Isaac
I'm fairly convinced its a stroage controller issue, not UCS !
Currently the indicated ports seem showing the lun; I would try to disconnect the cables for this ports on Controller 1 and 2; and see, if the lun is then seen on the other ports ?
Controller 1:
50:0a:09:82:90:21:18:54 <=======
vHBA-1
Controller 2:
50:0a:09:81:90:21:18:54 <=======
Walter.
Can get recommended Connectivity diagram of CISCO UCS FI to SAN switch..?
So that i will verify it with my current setup
Have a look at
http://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9500-series-multilayer-directors/white_paper_c11_586100.html
eg. Figure 1
or https://www.youtube.com/watch?v=aUECbrYi8Oo
or http://www.vce.com/asset/documents/infrastructure-platforms.pdf
which has a picture, of what you would like to do (see also attachment)
http://www.techrepublic.com/blog/the-enterprise-cloud/learn-how-san-fibre-mesh-works/
has a nice picture which explains, how the cabling between your MDS and storage processors should be done (same as I tried too explain before)
see also attachment
