chassis to FI via FEX - not discovered
robad
Hi All,
I'm having to FEXes, each is connected to FI
Fex1 to FI-A
Fex2 to FI-B
I succeeded with connected C-Series Server
But now, when I'm connecting a chassis to it, the FI is not dicovering it
I connected 4 ports from left IOM to FEX1, and 4 ports from right IOM to FI-B
What can be wrong ?
Thanks in advance,
2 Accepted Solutions
ITM-Team
Greetings,
I think the connection FEX <-> Chassis is not supported as the IO-Module in the chassis is already a FEX and therefore a connection FEX <-> FEX should not work. We are only using Rack Servers with our 2232PP FEX.
Your cabling sounds good, maybe you need to adjust your Chassis/FEX Discovery Policy (Equipment -> Policies -> Global Policies).
Do you have any other chassis connected directly to your FIs that are discovered correctly?
 Martin
That is correct.
You can't double stack a iom(fex) on another fex.
You need to connect your IOM fabric connections to the FIs, which ports will be configured as 'server' ports.
Kirk...
5 Replies 5
ITM-Team
Greetings,
 Martin
That is correct.
Kirk...
Hi guys,
Thanks for your replies
Yes, there are chassis that connecte directy to the FI and they are discovered &  working .
I tried to connect a chassis via FEX, because the chassis is very very far from the FI's rack
so you are saying there is no solution for my case ? [a chassis that located far from the FI ]
Maybe a UCS Mini is a solution: https://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-mini/index.html
That would be an independent chassis with two Fabric Interconnect IO Modules. But that means you have to configure an maintain another UCS Domain.
thanks !
I'll keep it as is, and connect a more closer chassis
thanks guys for the answers
