Cisco Custom ISO - VMWare ESXi after CVE -2015-7547
Levent Ozturk
Hi all,
Does anybody know if a new Cisco Custom iso will be available soon that resolves the vulnerability issue with GNU glibc (Feb 2016) for ESXi 5.5 or do we have to implement a manual workaround?
VMWare has already published a patch (ESXi 5.5 Patch 10) resolving the issue but when i install in test environment i see that some Cisco drivers are removed (enic and fnic) I checked this thread to find out if i can manually add them back:
https://supportforums.cisco.com/discussion/12338306/cisco-customized-esxi-55-update-2-image
but i could not figure out what is required or if installing only these two drivers would be enough..
Thanks in advance for your comments & guidance.
regards,
levent
Walter Dey
Hi Levent
I don't think that Cisco will publish a revised OEM version. Therefore I would install the VMware patched iso version, and then upgrade the enic/fnic drivers.
The proper version and the download URL can be found in
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Good luck
Walter.
Walter Dey
Hi Levent
Good luck
Walter.
Kirk J
Cisco generally releases an OEM/customized image per Update release (i.e. GA, U1, U2, U3).
Kirk...
