Cisco UCS 200 M2 Fans running at high speed
xxxionukk
Hi All
I have two of UCS C200 M2 servers which have this problem since 3 years now.
The problem is that these servers keep revving up like they are going to take off.
As such there are no faults in the CIMC tech support file  which is why TAC are unable to find the issue.
I took a video of this issue and uploaded it so TAC could see what I meant.
Initally we updated the firmware which is now 1.4(3x) , replaced both the PSUs in the servers.
I was then told that the temperature sensors might have caused this and finally both the chasis were replaced.
The servers are in the same datacentre in the same rack one above the other so there are no issues with temperature.
These were replaced 11 months ago and today once again I see one server revving up.
The current RPM is 9000 to 14500.
Is there any advice I could get on this please?
link to the video http://www.dailymotion.com/video/k656zoiXIOnkgrcdOr6
Saurabh Kothari
hey,
did you open another TAC case for this issue?
do you have any PCIe card(s) installed in the server? if yes then please list.
