Cisco Unified Computing System - Smart Play Expiry
Syed Farhan Ali
Level 4
Level 4
Dear Friends,
I have quoted the part number "UCS-SPL-5108-AC2" to one of our clients and it has been really cost effective since we have submitted the lowest bid due to smartplay selection.
I need to know the validity of this Smartplay Promotion, when is it going to expire, since we are in tendering process and it may take sometime to close.
Following is the BOQ.
UCS-SPL-5108-AC2UCS SP Select 5108 AC2 Chassis w/2208 IO, 4x SFP cable 3m1
CAB-BS1363-C19-UKBS-1363 to IEC-C19 14ft UK4
SFP-H10GB-CU3M10GBASE-CU SFP+ Cable 3 Meter4
UCS-IOM-2208XPUCS 2208XP I/O Module (8 External, 32 Internal 10Gb Ports)2
N01-UAC1Single phase AC power module for UCS 51081
N20-CAKAccessory kit for UCS 5108 Blade Server Chassis1
N20-CBLKB1Blade slot blanking panel for UCS 5108/single slot8
N20-FAN5Fan module for UCS 51088
N20-FW012UCS Blade Server Chassis FW Package 2.21
UCSB-5108-PKG-HWUCS 5108 Packaging for chassis with half width blades.1
UCSB-PSU-2500ACDV2500W Platinum AC Hot Plug Power Supply - DV4
UCSB-B200-M4-UUCS B200 M4 w/o CPU, mem, drive bays, HDD, mezz (UPG)8
UCS-CPU-E52695D2.30 GHz E5-2695 v3/120W 14C/35MB Cache/DDR4 2133MHz16
UCS-MR-1X162RU-A16GB DDR4-2133-MHz RDIMM/PC4-17000/dual rank/x4/1.2v64
UCS-MR-1X081RU-A8GB DDR4-2133-MHz RDIMM/PC4-17000/single rank/x4/1.2v64
UCSB-MLOM-40G-03Cisco UCS VIC 1340 modular LOM for blade servers8
UCSB-LSTOR-BKFlexStorage blanking panels w/o controller, w/o drive bays16
UCSB-HS-EP-M4-FCPU Heat Sink for UCS B200 M4/B420 M4 (Front)8
UCSB-HS-EP-M4-RCPU Heat Sink for UCS B200 M4/B420 M4 (Rear)8
C1UCS-OPT-OUTCisco ONE Data Center Compute Opt Out Option8
CON-3SNT-SL6508A23YR SMARTNET 8X5XNBD, UCS B 5108 SP AC2 Chassis1
CON-3SNT-B200M4U3YR SMARTNET 8X5XNBDUCS B200 M4 w/o CPU,m,dr b, HDD,m (UPG)8
Farhan.
2 Accepted Solutions
Farhan Mohamed
Which smartplay bundles you are talking about we have many, Currently SP9 or Smartplay select is the running program currently. The quoting expiration for this is 23rd Jan 2016, and the ordering expiration would be Feb 27th 2016.
Does this answer your question?
I can see there are two parts configured, one is Chassis with part UCS-SPL-5108-AC2. Other is ala-carte B200 M4 option. The chassis and bundle options for B200 M4 is included in SPL bundles. That is correct
Farhan Mohamed
Dear Farhan,
Thanks. I have quoted this Part Number "UCS-SPL-5108-AC2".
The rest of the details are shared in BOM.
Are these included in the Smart Play Bundle that is going to expire in Jan 2016 ?
Farhan.
