Collect full info for UCS
jalmishal
Hi All
we plan to move to hyperflex from our UCS  but not all servers
we will move only the consumes more resources so now I need to collect the UCS Information,
such as
CPU , CPU Cores, CPU usage % Memory, Memory usage % etc .. by each blade and better if by each VM
since we'd install on it
some Hyper-V and some ESXi 5.5 and some XenServer
and we've a couple of UCS 5108 configured in HA
with mix blade servers (B200 M2 , B230 M1)
Thanks in advance.
Kirk J
Greetings.
From equipment inventory perspective, you can 'export' from the equipment, chassis view to a .csv file.
There are also some powershell scripts you can run that connect to the UCSM and collect an inventory for.
Do keep in mind that all M1 servers, 6100 series FIs, a portion of M2 servers, and some adapters are not supported in in UCSM 3.x.
Please check the deprecated hardware list at https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-1.html#reference_D8E0F1697DB8476D8B3016D38ECB6E72
Your CPU and memory usage info, is actually an OS metric so you will need to collect that info from your OS/Hypervisor, which can be accomplished with a vmware powertools/powershell script.
Kirk...
