03-01-2019 06:41 AM - edited 03-01-2019 01:38 PM
I deploy actually a Stretch Hyperflex. I am blocking at the step of the creation of the cluster. Indeed, the communication between the FI6332 and the nexus 9000 doesn't work.
There are port channel between N900 and FI6332, all vlan are trunk in the port channel in the nexus.
Do you have idea why there are no communication ?
How can i check the configuration of the port channel on the FI ?
The Esx on the FI can ping between us
Thank you
Solved! Go to Solution.
03-05-2019 05:14 AM
Just to confirm, you have no other uplinks for the FIs going to any other switches (or even the same N9Ks)?
Also, your spanning tree should be set to type 'spanning-tree port type edge trunk' for interfaces facing FI ports in 'end host' mode.
Kirk...
03-03-2019 08:17 AM
Are you learning any macs on the N9k on the PCs in question in the VLANs you are expecting?
Do you happen to have different native vlan settings between the FIs and the N9K?
On your N9k and FIs do a show run int PO xx
and paste the output
On the FIs, you'll have to 'connect nxos' first before running the show commands.
Kirk...
03-04-2019 12:35 AM
There are no learging macs.
here the configuration on the FI :
interface port-channel2
description U: Uplink
switchport mode trunk
switchport trunk allowed vlan 1,16,20,97-98
lacp max-bundle 16
pinning border
speed 40000
Here the configuration on the N9K-1 :
interface port-channel1003
description Uplink Hyperflex FRFI6332-2B
spanning-tree port type network
vpc 1003
Here the configuration on the N9K-2 :
vpc 1003
For the native vlan, the PO are in trunk mode, otherwise the native vlan is the 1 on the both.
Thank you for your help
03-05-2019 05:14 AM
Kirk...
03-06-2019 06:10 AM - edited 03-06-2019 07:22 AM
There are no another uplink.
The solution was to configure the spanningtree in end host mode. The FI is not a switch and act as a server whith many ports/mac. With the configuration "type network" the traffic is blocked.
Thank you
