Configuration RAID Controller in C-240-M3
whenusayloveme
Hi All,
     Any one please, guide me how to setup raid on it? I can't see any LSI set up utility during POST (no CTRL+M option available).
Note: CIMC firmware version 1.4(5g)
Winai.
17 Replies 17
Paolo,
I don't believe you can modify the block size on the 9216.  I'll double check and update this thread if I'm wrong.  I believe you can change the block sizing on the 9265 and higher RAID cards.
Robert
Paolo,
I did investigate this.  You can modify the Stripe size via the WebBIOS utility.  I believe this is what you're after.
Robert
Hi Robert,
     Is strip size same as block size? I saw the strip size setting when I pressed Ctrl-H upon boot-up, but the max was only 1mb.  I changed the block size via Vsphere Client 4.1 in the storage link.
