Connect a UCS-FI-6454 to Chassi 9508
student5500
I need to connect a UCS-FI-6454 to Chassi 9508 (IO module UCSX-I-9108-25G)
The Fabric interconnects don't seem to know the chassi, for "show chassis " command I get this output  - "Identity Unestablishable Acknowledged".
Is this the way to connect the FIs and the chassi ?
Brian Morrissey
It sounds like you have the 6454 and 9508 in UCSM Mode?  As of today, it'll need to be in Intersight Managed Mode (IMM) to discover the X-series.
The following is a good reference on quickly standing it up:
https://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-x-series-modular-system/ucs-x-series-quick-start-guide.html
If you are still running in UCS Manager Managed Mode, upgrading to 4.3(2b) or newer (which supports UCS-X chassis 9508 and UCS-X IFMs), will make the IFMs and chassis discover successfully.
tdubb123
i have same question. does it make a difference if I connect 1/1 and 1/2 to fabA or do i use 1/1 and 1/5 to fabA
