Connection between FEX and FI
ccychow01
We have the following setup,
UCS-C <> N2K <> FI-6248 <> N9K
Is the connection between FEX (N2K) and FI (FI-6248) must be an MMF cable, could we use single mode SFP+?
I found below Cisco DOC about the uplinks connection from FEX to FI could only use twinaxial or MMF type SFP,, is that a must?
Cisco UCS C-Series Server Integration with Cisco UCS Manager 2.2 - Configuring SingleConnect [Cisco UCS C-Series Rack-M…
At least four cables for uplinks from the FEX to FIs. You can either use 10-gb twinaxial cable or one of the following SFP type cables:
  • SFP - 10GE-SR
  • FET - 10GE
Thanks in advance.
padramas
Hello Chris,
Yes, these are the supported transceivers to connect FEX NIF ports and FI ports.
Padma
padramas
Hello Chris,
Padma
