11-09-2011 03:02 PM - edited 03-01-2019 10:08 AM
I'm getting the attached error message.
End point timed out. Check for IP, password, space or access or access related issues.
Please look at the attached file.
11-09-2011 03:13 PM
Looks like a user/pass problem. Can you try downloading from that same FTP server from another client such as filezilla to test the path and credentials?
Robert
11-10-2011 05:41 AM
Verified credentials, but still not working? Any ideas?
11-10-2011 05:55 AM
1. Is the FTP server on the same subnet as the UCS virtual IP? (Ruling out any firewalls etc).
2. Can you try using a TFTP or SCP server instead
3. Which version of UCSM are you currently on
Note: Ensure you delete any failed download task before re-attempting to download. This will clear any stale info and ensure a fresh attempt.
Another thing to try is to connect to the UCS CLI via SSH or Telnet, connect to the Management context with "connect local-m" and test ping to your FTP server IP.
Let me know how you go and we'll continue to t-shoot this for you.
Robert
