Fabric Extender and Blade server connectivity(Cabling)
Sushant Jain
There is lot of information available about how a Fabric extender connects to the Fabric interconnect. e.g. SFP+ ports, cabling etc.
I am bit a confused, how does connectivity happen between the blade server and fabric extender inside the chassis.
The information available only gives us idea about the possible network cards in the blade servers.
I want to understand, how actual connectivity is done between the blade servers and fabric extenders.
Is it through some cables or anything else? Please help.
Sushant
5 Replies 5
Walter Dey
Hi Sushant
This has been discussed before
https://supportforums.cisco.com/discussion/12130401/vnic-bandwidth-question
https://supportforums.cisco.com/discussion/12207581/m81kr-vic-1240-and-vic-1280
https://supportforums.cisco.com/discussion/11897266/vic1240-and-2208xp
https://supportforums.cisco.com/discussion/11500981/vic-1280-vs-vic-1240-port-expander
https://supportforums.cisco.com/discussion/11900386/10g-between-adpater-and-blades-vic12401280
https://supportforums.cisco.com/discussion/12321671/ucs-enabledisable-dce
Cheers
Walter.
Hi Walter,
Thanks for responding!!
My question is mostly on the physical connectivity between Fabric Extender and Blade server.
In my case I am considering the following:
1 B200M3 (1 UCSB-MLOM-40G-01) blade server
1 2204 XP  Fabric Extender
I checked the links but couldn’t find my answer.
May be I need a little explanation.
Please explain about the physically connectivity in little detail.
Sushant
Hi Sushant
Check
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/B200M3_SpecSheet.pdf
p 50 ff, which will answer all your questions (I hope)
Kind Regards
Walter.
Hi Walter,
I have looked into that document before :)
My questions is on the physical connectivity.
How are they connected physically, I mean LAN cable, twin copper cable etc.?
What is the physically connectivity between them?
Thanks & Regards,
Sushant Jain
Blade Server - IOM (FEX) goes over the chassis backplane.
the 2204 has 2x10G backplane connections per chassis slot (and fabric)
the 2208 has 4x10G backplane connections per chassis slot (and fabric)
All I/O adaptors (VIC-1240/1280) are dual homed.
No external cables !
