FCoE Northbound Connectivity ISSUES
marco.mosangini
Hi all,
i've configured this topology for Ethernet and FCoE uplink from 6248UP to 5548UP:
Multi-Hop FCoE
When i check flogi database from n5k the result is:
  • n5kA --> no vfc to 6248A was logged
  • n5kB --> vfc to 6248B is up and running
This is sh int vfc21 (n5kA FCoE Po to 6248A):
vfc21 is down (Initializing)
    Bound interface is port-channel21
    Hardware is Ethernet
    Port WWN is 20:14:54:7f:ee:b2:fa:7f
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 101
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
This is sh int vfc22 (n5kB FCoE Po to 6248A):
vfc22 is trunking
    Bound interface is port-channel22
    Port WWN is 20:15:54:7f:ee:af:49:bf
    Port mode is TF
    Port vsan is 102
    Trunk vsans (admin allowed and active) (102)
    Trunk vsans (up)                       (102)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
      740 frames input, 73824 bytes
        0 discards, 648 errors
      759 frames output, 132936 bytes
    Interface last changed at Wed Apr  3 09:32:57 2013
This is sh ru int vfc755 (6248A FCoE Po to n5kA):
vfc755 is trunking (Not all VSANs UP on the trunk)
    Hardware is Virtual Fibre Channel
    Port WWN is 22:f2:54:7f:ee:aa:cf:3f
    Admin port mode is NP, trunk mode is on
    Port mode is TNP
    Port vsan is 101
    Trunk vsans (admin allowed and active) (1,101)
    Trunk vsans (up)                       ()
    Trunk vsans (initializing)             (1,101)
    Interface last changed at Wed Apr  3 19:53:21 2013
This is sh ru int vfc756 (6248B FCoE Po to n5kB):
vfc756 is trunking (Not all VSANs UP on the trunk)
    Port WWN is 22:f3:54:7f:ee:aa:d2:3f
    Port mode is TNP
    Port vsan is 102
    Trunk vsans (admin allowed and active) (1,102)
    Trunk vsans (initializing)             (1)
    1 minute input rate 8 bits/sec, 1 bytes/sec, 0 frames/sec
      1187 frames input, 163868 bytes
      1930 frames output, 202972 bytes
    Interface last changed at Wed Apr  3 07:22:45 2013
Could someone help me solving this painful issue??
16 Replies 16
This was the output from N5KA and B (swp01201 is N5KA swp01202 is N5KB):
swp01201# show run int e2/11-12
!Command: show running-config interface Ethernet2/11-12
!Time: Fri Apr  5 17:05:57 2013
version 6.0(2)N1(2)
  description -- mgp01200A Eth1/27 (Cisco UCS FI 6248UP) --
  switchport mode trunk
  switchport trunk allowed vlan 101
  channel-group 21 mode active
interface Ethernet2/12
  description -- mgp01200A Eth1/28 (Cisco UCS FI 6248UP) --
swp01201# show int e2/11-12
Ethernet2/11 is up
Dedicated Interface
  Belongs to Po21
  Hardware: 1000/10000 Ethernet, address: 547f.eeb0.dc0a (bia 547f.eeb0.dc0a)
  Description: -- mgp01200A Eth1/27 (Cisco UCS FI 6248UP) --
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 02:29:47
  4 interface resets
  30 seconds input rate 120 bits/sec, 0 packets/sec
  30 seconds output rate 1168 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 144 bps, 0 pps; output rate 520 bps, 0 pps
  RX
    0 unicast packets  2348 multicast packets  0 broadcast packets
    2348 input packets  540429 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    1721 unicast packets  5772 multicast packets  0 broadcast packets
    7493 output packets  4611803 bytes
    1721 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
Ethernet2/12 is up
Dedicated Interface
  Belongs to Po21
  Hardware: 1000/10000 Ethernet, address: 547f.eeb0.dc0b (bia 547f.eeb0.dc0b)
  Description: -- mgp01200A Eth1/28 (Cisco UCS FI 6248UP) --
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  4 interface resets
  30 seconds output rate 104 bits/sec, 0 packets/sec
    input rate 208 bps, 0 pps; output rate 160 bps, 0 pps
  RX
    0 unicast packets  5794 multicast packets  0 broadcast packets
    5794 input packets  761442 bytes
    0 Rx pause
  TX
    1 unicast packets  2363 multicast packets  0 broadcast packets
    2364 output packets  589812 bytes
    1 jumbo packets
    0 Tx pause
swp01201# show vsan database
% Invalid command at '^' marker.
swp01201# show vsan ?
  <1-4094>    VSAN id range
  >           Redirect it to a file
  >>          Redirect it to a file in append mode
  internal    Show various event logs of VSAN Mgr
  membership  Show membership information
  usage       Show vsan usage in the system
  |           Pipe command output to filter
swp01201# show vsan usage
2 vsan configured
configured vsans:1,101
vsans available for configuration:2-100,102-4078,4080-4093
swp01201# show flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc2/16           101   0x1c0020  50:03:08:c3:8c:83:50:01 50:03:08:c3:8c:83:50:00
                           [Quantum-i40-1]
Total number of flogi = 1.
This are the N5KA and B confs:
!Time: Fri Apr  5 17:09:12 2013
version 6.0(2)N1(2)
feature fcoe
hostname swp01201
feature npiv
feature fport-channel-trunk
feature telnet
cfs eth distribute
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
logging level flogi 5
no password strength-check
ip domain-lookup
logging event link-status default
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
policy-map type network-qos jumbo
  class type network-qos class-fcoe
    pause no-drop
    mtu 2158
  class type network-qos class-default
    mtu 9000
    multicast-optimize
system qos
  service-policy type qos input fcoe-default-in-policy
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type network-qos fcoe-default-nq-policy
control-plane
  service-policy input copp-system-policy-customized
slot 1
slot 2
  port 13-16 type fc
snmp-server user admin network-admin auth md5 0x00b24de1ed629c0b8cb2cbd016993285 priv 0x00b24de1ed629c0b8cb2cbd016993285 localizedkey
ntp server 172.16.4.10 use-vrf management
ntp server 172.16.4.11 use-vrf management
aaa authentication login default group AD local
vrf context PIPPO
  ip route 0.0.0.0/0 172.16.3.254
vrf context management
  ip domain-name lab.lan
  ip name-server 172.16.4.10 172.16.4.11
  ip route 0.0.0.0/0 172.16.2.254
vlan 1-2
vlan 101
  fcoe vsan 101
  name TST_FCOE_FABRIC_A
vlan 1000
  name TST_MIR_TEST
vlan 1722
  name TST_INT_MGMT
vlan 1723
  name TST_INT_VRF
vlan 1724
  name TST_INT_SRV
vlan 4048
  fcoe vsan 1
  name FCOE_NATIVE_VSAN
vlan 4065
  name TST_PRIV_CONTROL
vlan 4066
  name TST_PRIV_PACKETS
vlan 4070
  name TST_PRIV_NFS
vlan 4081
  name TST_PRIV_ISCSI_1
vlan 4082
  name TST_PRIV_ISCSI_2
vlan 4090
  name TST_PRIV_VMOTION
spanning-tree port type edge bpduguard default
spanning-tree port type edge bpdufilter default
spanning-tree port type network default
vpc domain 10
  role priority 10
  peer-keepalive destination 172.16.2.242 source 172.16.2.241
  delay restore 150
port-profile default max-ports 512
vsan database
  vsan 101 name "FABRIC_A"
device-alias database
  device-alias name Quantum-i40-1 pwwn 50:03:08:c3:8c:83:50:01
  device-alias name srp01201-vmhba1 pwwn 20:00:00:25:b5:aa:00:0f
  device-alias name srp01202-vmhba1 pwwn 20:00:00:25:b5:aa:00:1f
device-alias commit
fcdomain fcid database
  vsan 101 wwn 22:f2:54:7f:ee:aa:cf:3f fcid 0x1c0000 dynamic
  vsan 101 wwn 20:00:00:25:b5:aa:00:0f fcid 0x1c0001 dynamic
!              [srp01201-vmhba1]
  vsan 101 wwn 50:03:08:c3:8c:83:50:01 fcid 0x1c0020 dynamic
!              [Quantum-i40-1]
  vsan 101 wwn 20:00:00:25:b5:aa:00:1f fcid 0x1c0002 dynamic
!              [srp01202-vmhba1]
  vsan 101 wwn 20:00:00:25:b5:aa:00:0e fcid 0x1c0003 dynamic
  vsan 101 wwn 20:00:00:25:b5:aa:00:1e fcid 0x1c0004 dynamic
interface Vlan1
interface Vlan1723
  description TST VRF TO FW
  no shutdown
  vrf member PIPPO
  ip address 172.16.3.252/24
  hsrp version 2
  hsrp 1723
    preempt
    priority 200
    ip 172.16.3.253
interface Vlan1724
  description TST SERVER
  no shutdown
  vrf member PIPPO
  ip address 172.16.4.253/24
  hsrp version 2
  hsrp 1724
    preempt
    priority 200
    ip 172.16.4.254
interface port-channel1
  description -- VPC fwp01201A (Fortinet Fortigate 200B) --
  spanning-tree port type edge trunk
  speed 1000
interface port-channel2
  description -- VPC fwp01201B (Fortinet Fortigate 200B) --
interface port-channel10
  description -- VPC PEER LINK --
  vpc peer-link
interface port-channel11
  description -- VPC stp01201 (Netapp FAS2240-4) --
  vpc 11
interface port-channel12
  description -- VPC stp01202 (Netapp FAS2240-4) --
  vpc 12
interface port-channel13
  description -- VPC mgp01200A (Cisco UCS FI 6248UP) --
  vpc 13
interface port-channel14
  description -- VPC mgp01200B (Cisco UCS FI 6248UP) --
  vpc 14
interface port-channel15
  description -- VPC swp01203 (Cisco Catalyst 2960S) --
  spanning-tree port type normal
  speed 1000
  vpc 15
interface port-channel16
  description -- VPC stp01210 (Netgear ReadyNAS 3200) --
  switchport access vlan 1724
  speed 1000
  vpc 16
interface port-channel21
  description -- mgp01200A (Cisco UCS FI 6248UP) --
  spanning-tree bpdufilter enable
interface vfc21
  bind interface port-channel21
  switchport trunk allowed vsan 101
  switchport description -- mgp01200A (Cisco UCS FI 6248UP) --
  no shutdown
vsan database
  vsan 101 interface vfc21
  vsan 101 interface fc2/15
  vsan 101 interface fc2/16
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
  no shutdown
interface Ethernet1/1
  description -- stp01201 e1a (Netapp FAS2240-4) --
  channel-group 11 mode active
interface Ethernet1/2
  description -- stp01202 e1a (Netapp FAS2240-4) --
  channel-group 12 mode active
interface Ethernet1/3
  description -- mgp01200A Eth1/19 (Cisco UCS FI 6248UP) --
  channel-group 13 mode active
interface Ethernet1/4
  description -- mgp01200B Eth1/19 (Cisco UCS FI 6248UP) --
  channel-group 14 mode active
interface Ethernet1/5
  description -- swp01202 Eth1/5 (Cisco Nexus 5548UP) --
  channel-group 10 mode active
interface Ethernet1/6
  description -- swp01202 Eth1/6 (Cisco Nexus 5548UP) --
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
  description -- stp01210 eth0 (Netgear ReadyNAS 3200) --
  speed 1000
  channel-group 16 mode active
interface Ethernet1/16
interface Ethernet1/17
  description -- swp01203A Gi1/11 (Cisco Catalyst 2960S) --
  speed 1000
  channel-group 15 mode active
interface Ethernet1/18
  description -- swp01203B Gi1/11 (Cisco Catalyst 2960S) --
  speed 1000
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
  description -- fw01201A port13 (Fortinet Fortigate 200B) --
  speed 1000
  channel-group 1 mode active
interface Ethernet1/22
  description -- fw01201A port14 (Fortinet Fortigate 200B) --
  speed 1000
interface Ethernet1/23
  description -- fw01201B port15 (Fortinet Fortigate 200B) --
  speed 1000
interface Ethernet1/24
  description -- fw01201B port16 (Fortinet Fortigate 200B) --
  speed 1000
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet2/4
interface Ethernet2/5
interface Ethernet2/6
interface Ethernet2/7
interface Ethernet2/8
interface Ethernet2/9
interface Ethernet2/10
interface mgmt0
  vrf member management
  ip address 172.16.2.241/24
clock timezone CET 1 0
clock summer-time CET 5 Sun Mar 02:00 5 Sun Oct 03:00 60
line console
line vty
  exec-timeout 15
boot kickstart bootflash:/n5000-uk9-kickstart.6.0.2.N1.2.bin
boot system bootflash:/n5000-uk9.6.0.2.N1.2.bin
interface fc2/15
interface fc2/16
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
!Full Zone Database Section for vsan 101
zone name Tape-Area-Network vsan 101
    member pwwn 50:03:08:c3:8c:83:50:01
!               [Quantum-i40-1]
    member pwwn 20:00:00:25:b5:aa:00:0f
!               [srp01201-vmhba1]
    member pwwn 20:00:00:25:b5:aa:00:1f
!               [srp01202-vmhba1]
zone name TAN vsan 101
zoneset name TAN vsan 101
    member Tape-Area-Network
zoneset activate name TAN vsan 101
!Time: Fri Apr  5 17:09:28 2013
version 6.0(2)N1(2)
feature fcoe
hostname swp01202
feature npiv
feature telnet
cfs eth distribute
feature hsrp
feature lacp
feature vpc
feature lldp
ip domain-lookup
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
    pause no-drop
    mtu 2158
    mtu 9000
    multicast-optimize
system qos
policy-map type control-plane copp-system-policy-customized
  class copp-system-class-hsrp-vrrp
    police cir 1024 kbps bc 256000 bytes
  class copp-system-class-l3dest-miss
    police cir 64 kbps bc 16000 bytes
control-plane
slot 1
slot 2
  port 13-16 type fc
snmp-server user admin network-admin auth md5 0x6c6734dd7ef798d74d574992557b2b1d priv 0x6c6734dd7ef798d74d574992557b2b1d localizedkey
vrf context PIPPO
vlan 1-2
vlan 102
  fcoe vsan 102
  name TST_FCOE_FABRIC_B
vlan 1000
  name TST_MIR_TEST
vlan 1722
  name TST_INT_MGMT
vlan 1723
  name TST_INT_VRF
vlan 1724
  name TST_INT_SRV
vlan 4048
  fcoe vsan 1
vlan 4065
vlan 4066
vlan 4070
  name TST_PRIV_NFS
vlan 4081
vlan 4082
vlan 4090
vpc domain 10
  role priority 20
  peer-keepalive destination 172.16.2.241 source 172.16.2.242
  delay restore 150
vsan database
  vsan 102 name "FABRIC_B"
  device-alias name srp01201-vmhba2 pwwn 20:00:00:25:b5:bb:00:0f
  device-alias name srp01202-vmhba2 pwwn 20:00:00:25:b5:bb:00:1f
device-alias commit
  vsan 102 wwn 24:03:54:7f:ee:aa:d2:00 fcid 0x0f0000 dynamic
  vsan 102 wwn 20:00:00:25:b5:bb:00:0f fcid 0x0f0001 dynamic
!              [srp01201-vmhba2]
  vsan 102 wwn 20:00:00:25:b5:bb:00:1f fcid 0x0f0002 dynamic
!              [srp01202-vmhba2]
  vsan 102 wwn 20:00:00:25:b5:bb:00:0e fcid 0x0f0003 dynamic
  vsan 102 wwn 20:00:00:25:b5:bb:00:1e fcid 0x0f0004 dynamic
  vsan 102 wwn 22:f3:54:7f:ee:aa:d2:3f fcid 0x0f0040 dynamic
  vsan 102 wwn 50:03:08:c3:8c:83:50:01 fcid 0x0f0080 dynamic
!              [Quantum-i40-1]
interface Vlan1
interface Vlan1723
  no shutdown
  vrf member PIPPO
  ip address 172.16.3.251/24
  hsrp version 2
  hsrp 1723
    ip 172.16.3.253
interface Vlan1724
  no shutdown
  vrf member PIPPO
  ip address 172.16.4.252/24
  hsrp version 2
  hsrp 1724
    ip 172.16.4.254
  speed 1000
  vpc peer-link
  vpc 11
  vpc 12
  vpc 13
  vpc 14
  speed 1000
  vpc 15
  speed 1000
  vpc 16
interface port-channel22
  description -- mgp01200B (Cisco UCS FI 6248UP) --
  switchport trunk allowed vlan 102
interface vfc22
  bind interface port-channel22
  switchport trunk allowed vsan 102
  switchport description -- mgp01200B (Cisco UCS FI 6248UP) --
  no shutdown
vsan database
  vsan 102 interface vfc22
  vsan 102 interface fc2/15
  vsan 102 interface fc2/16
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
  no shutdown
  description -- stp01201 e1b (Netapp FAS2240-4) --
  description -- stp01202 e1b (Netapp FAS2240-4) --
  description -- mgp01200A Eth1/20 (Cisco UCS FI 6248UP) --
  description -- mgp01200B Eth1/20 (Cisco UCS FI 6248UP) --
  description -- swp01201 Eth1/5 (Cisco Nexus 5548UP) --
  description -- swp01201 Eth1/6 (Cisco Nexus 5548UP) --
  description -- stp01210 eth1 (Netgear ReadyNAS 3200) --
  speed 1000
  description -- swp01203A Gi1/12 (Cisco Catalyst 2960S) --
  speed 1000
  description -- swp01203B Gi1/12 (Cisco Catalyst 2960S) --
  speed 1000
  description -- fw01201B port13 (Fortinet Fortigate 200B) --
  speed 1000
  description -- fw01201B port14 (Fortinet Fortigate 200B) --
  speed 1000
  description -- fw01201A port15 (Fortinet Fortigate 200B) --
  speed 1000
  description -- fw01201A port16 (Fortinet Fortigate 200B) --
  speed 1000
  description -- mgp01200B Eth1/27 (Cisco UCS FI 6248UP) --
  channel-group 22 mode active
  description -- mgp01200B Eth1/28 (Cisco UCS FI 6248UP) --
interface mgmt0
  ip address 172.16.2.242/24
line console
line vty
  exec-timeout 15
interface fc2/15
interface fc2/16
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
!Full Zone Database Section for vsan 102
zone name Tape-Area-Network vsan 102
!               [Quantum-i40-1]
    member pwwn 20:00:00:25:b5:bb:00:0f
!               [srp01201-vmhba2]
    member pwwn 20:00:00:25:b5:bb:00:1f
!               [srp01202-vmhba2]
zone name TAN vsan 102
zoneset name TAN vsan 102
zoneset activate name TAN vsan 102
version 6.0(2)N1(2)
feature fcoe
hostname swp01202
feature npiv
feature telnet
cfs eth distribute
feature hsrp
feature lacp
feature vpc
feature lldp
ip domain-lookup
radius-server host bdc.lab.lan key 7 "vst01202k3mw3p" authentication accounting
radius-server host pdc.lab.lan key 7 "vst01202k3mw3p" authentication accounting
aaa group server radius AD
    server pdc.lab.lan
    server bdc.lab.lan
    use-vrf management
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
    pause no-drop
    mtu 2158
    mtu 9000
    multicast-optimize
system qos
control-plane
slot 1
slot 2
  port 13-16 type fc
vrf context PIPPO
vlan 1-2
vlan 102
  fcoe vsan 102
vlan 1000
  name TST_MIR_TEST
vlan 1722
  name TST_INT_MGMT
vlan 1723
  name TST_INT_VRF
vlan 1724
  name TST_INT_SRV
vlan 4048
  fcoe vsan 1
vlan 4065
vlan 4066
vlan 4070
  name TST_PRIV_NFS
vlan 4081
vlan 4082
vlan 4090
vpc domain 10
  role priority 20
  delay restore 150
vsan database
device-alias commit
!              [srp01201-vmhba2]
!              [srp01202-vmhba2]
!              [Quantum-i40-1]
interface Vlan1
interface Vlan1723
  no shutdown
  vrf member PIPPO
  hsrp version 2
  hsrp 1723
    ip 172.16.3.253
interface Vlan1724
  no shutdown
  vrf member PIPPO
  hsrp version 2
  hsrp 1724
    ip 172.16.4.254
  speed 1000
  vpc peer-link
  vpc 11
  vpc 12
  vpc 13
  vpc 14
  speed 1000
  vpc 15
  speed 1000
  vpc 16
interface vfc22
  no shutdown
vsan database
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
  no shutdown
  speed 1000
  speed 1000
  speed 1000
  speed 1000
  speed 1000
  speed 1000
  speed 1000
interface mgmt0
line console
line vty
  exec-timeout 15
interface fc2/15
interface fc2/16
interface fc2/13
interface fc2/14
interface fc2/15
interface fc2/16
!               [Quantum-i40-1]
!               [srp01201-vmhba2]
!               [srp01202-vmhba2]
Many tnx
M.
From FI (mgp01200-A is 6248A and mgp01200-B is 6248B):
mgp01200-A(nxos)# sh ru int eth1/27-28
!Command: show running-config interface Ethernet1/27-28
!Time: Fri Apr  5 15:10:07 2013
version 5.0(3)N2(2.11d)
  description C: FcoeUplink
  pinning border
  switchport trunk native vlan 4049
  switchport trunk allowed vlan 101-102,4048-4049
  no shutdown
  pinning border
  no shutdown
mgp01200-A(nxos)# sh int eth1/27-28
Ethernet1/27 is up
  Hardware: 1000/10000 Ethernet, address: 547f.eeaa.d002 (bia 547f.eeaa.d002)
  Description: C: FcoeUplink
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 02:45:10
  30 seconds input rate 1072 bits/sec, 134 bytes/sec, 0 packets/sec
  30 seconds output rate 120 bits/sec, 15 bytes/sec, 0 packets/sec
    input rate 400 bps, 0 pps; output rate 152 bps, 0 pps
  RX
    620 unicast packets  2089 multicast packets  0 broadcast packets
    2709 input packets  1664551 bytes
    620 jumbo packets  0 storm suppression bytes
0 giants      0 input error  0 short frame  0 overrun   0 underrun      0 watchdog  0 if down drop
    0 Rx pause
  TX
    0 unicast packets  838 multicast packets  0 broadcast packets
    838 output packets  192005 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
Ethernet1/28 is up
  Hardware: 1000/10000 Ethernet, address: 547f.eeaa.d003 (bia 547f.eeaa.d003)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 02:45:11
  30 seconds input rate 128 bits/sec, 16 bytes/sec, 0 packets/sec
  30 seconds output rate 56 bits/sec, 7 bytes/sec, 0 packets/sec
    input rate 160 bps, 0 pps; output rate 216 bps, 0 pps
  RX
    1 unicast packets  863 multicast packets  0 broadcast packets
    864 input packets  217352 bytes
    1 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    0 unicast packets  2083 multicast packets  0 broadcast packets
    2083 output packets  272154 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
mgp01200-B(nxos)# sh ru int eth1/27-28
!Time: Fri Apr  5 15:10:11 2013
  pinning border
  no shutdown
  pinning border
  no shutdown
mgp01200-B(nxos)# sh int eth1/27-28
Ethernet1/27 is up
  Hardware: 1000/10000 Ethernet, address: 547f.eeaa.d222 (bia 547f.eeaa.d222)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 02:44:44
  30 seconds input rate 72 bits/sec, 9 bytes/sec, 0 packets/sec
  30 seconds output rate 160 bits/sec, 20 bytes/sec, 0 packets/sec
    input rate 168 bps, 0 pps; output rate 248 bps, 0 pps
  RX
    0 unicast packets  859 multicast packets  0 broadcast packets
    859 input packets  225562 bytes
    0 Rx pause
  TX
    1246 unicast packets  1455 multicast packets  0 broadcast packets
    2701 output packets  312217 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
Ethernet1/28 is up
  Hardware: 1000/10000 Ethernet, address: 547f.eeaa.d223 (bia 547f.eeaa.d223)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  30 seconds output rate 40 bits/sec, 5 bytes/sec, 0 packets/sec
    input rate 264 bps, 0 pps; output rate 152 bps, 0 pps
  RX
    32 unicast packets  2084 multicast packets  0 broadcast packets
    2116 input packets  339814 bytes
    2 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    11 unicast packets  841 multicast packets  0 broadcast packets
    852 output packets  195944 bytes
    1 jumbo packets
    0 Tx pause
  1 interface resets
mgp01200-B(nxos)#
