FI L1/L2 links loss
delahais
One of my customers asks me about the L1/L2 links loss between the 2 FI.
On my mind, this case must not be happened, that why we have 2 links but I do not know what have happened exactly in this case... the 2 FI become master in the UCS cluster....
any idea or already tester ?
thx
Robert Burns
The L1/L2 are by the Data Management Engine (DME) to sync config only - there's no datapath on these links.
In the event these links both go down, there's a back mechanism built into the system to prevent split brain.  Each Chassis has an SEEPROM (flash).  Within the SEEPROM there is a shared area that each FI can read & write to, and two sub-areas; one owned by each FI in which only that FI can write to.  The sub-areas are used to store information about config DB ownership in the even an FI fails, changes are made and it's re-introduced.  This prevents "stale" config over-writing any changes made while one FI was offline.
If there's a cluster llink (L1/L2) failure, the FI's read and write small counters to the shared area.  This serves as a secondary heartbeat to alert the other FI is still active.  During this time the cluster puts itself into a "Failed-Link" state and prevents any primary/secondary elections.  Everything stays as-si - Primary remains primary, secondary remains secondary.
Robert
Robert Burns
Robert
Just to add to it, there is great doc about UCSM architecture.
Split brain scenario is discussed under " Availability " section
Cisco UCS Manager Architecture
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10281/white_paper_c11-525344.html
Padma
delahais
thx Robert and Padma, for your reply.
By searching, i have found this url with pretty nice explaination :
http://ucsguru.com/2012/11/07/ha-with-ucsm-integrated-rack-mounts/
best regards.
Nicolas.
