Firmware Upgrade from 2.2.3e to 3.1.1h on a Cisco UCS B200 M4 - Unable to match Boot Policy
troyheiss
I had updated our UCSM from 2.2.3e to 3.1.1h successfully a couple of weeks ago and then felt comfortable enough with proceeding with the Server Firmware updates after updating our DR/Test environment successfully.
The update failed and now I'm stuck at a screen "Unable to match Boot Policy" on the box.  It was running VMware 5.1 on a RAID pair of SD Cards.
The Controller State is "Disconnected Partition from Host" with a RAID State of "Enabled Paired Invalid Secondary."
Thinking that the Firmware update didn't complete...I decommissioned the blade, the re-acknowledged it, but there's no change.
Anyone else come across this?  It's kinda funny in that of course the DR/Test environment went just fine, but my first Prod VMware box attempt was a failure.
AFROJ AHMAD
Hi Troy,
You must be booting the it from SAN.
most commonly this issue is seen if there is a mismatch in the LUN or Target is not configured correctly.
For e.g
UCSM is trying to boot from LUN0 and SAN is setup for LUN1.
Please check
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
