From Setup to Optimization: Navigating Cisco UCS C-Series Servers AMA
Brooke Hammer
Community Manager
Community Manager
Ask Me Anything Event
Welcome to the Cisco UCS C-Series Servers session! Whether you're setting up your first server or optimizing an existing deployment, this event is your one-stop destination for everything UCS C-Series. Our expert engineers, Prabhu Subramanian, Joy Pal, Shashanka Tripathy and Anshuman Garg will be available from February 24, 2025 through March 14, 2025 to assist you with any queries or features during Deployment, Maintenance and Troubleshooting.
Join us for an Ask Me Anything (AMA) event where you can dive deep into Cisco Data Center C-Series Servers!
What is it?
The Cisco UCS C-Series servers provide a flexible, scalable, and high-performance platform for data centers. From initial setup to advanced configurations and optimization, UCS C-Series offers a comprehensive solution for your business needs.
Get Expert Advice!
This is your chance to get advice from Cisco UCS experts. Whether you're a network admin, server engineer, or part of a larger IT team, we’ll be here to answer your questions about UCS C-Series deployment, performance enhancements, and system troubleshooting.
Official Resources:
Join us for this insightful Ask Me Anything session and take your UCS C-Series skills from setup to optimization.  Let's uncover the solutions to your challenges and explore the vast possibilities in this dynamic field.
Note: Please post your post as a comment below no later than March 14, 2025.
Post your question below by clicking "Reply"
(Answers will be processed depending on the availability of the experts)
Don't forget to thank the expert by giving it a helpful vote!
Our experts
Prabhu Subramanian
Technical Consulting Engineer
Joy Pal
Shashanka Tripathy
Anshuman Garg
25 Replies 25
Hi Ankit,
The standalone C-series server can be claimed and managed on intersight for server lifecycle management.
Refer below documents for the claiming and managing Standalone server in Intersight:
https://intersight.com/help/saas/resources/conversion_procedures#converting_a_server_in_standalone_mode_to_intersight_managed_mode
Server lifecycle management:
https://intersight.com/help/saas/resources/cisco_intersight_managed_mode_configuration#server_lifecycle
Intersight Managed Mode (IMM) delivers a cloud-based, unified management experience for Cisco UCS Fabric Interconnect systems, while UCS Manager Managed Mode (UMM) is the traditional on-premise solution. IMM provides benefits like centralized management, seamless migration, and cloud flexibility, whereas UMM focuses on local control with established interfaces.
For more detailed information about the benefits, please refer below document:
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/intersight/intersight-ds.html
Hey Team ,
How different is C-series server in terms of cost efficiency when compared with other server solutions ?
amankusi
On Cisco UCS C220 M6 Rack Server - Is a PCIe slot the only way to support networking adapters (VIC or NIC)?
Hi Aman,
Many thanks for your post,
In general Most of the VIC and NIC cards on UCSC-C220-M6 Server are housed on PCIe slots. however there are few models for eg :
UCSC-M-V25-04
UCSC-M-V100-04
UCSC-M-V5Q50GV2
can be mounted on MLOM card slot as well.
Please refer below docs:
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c220m6-sff-specsheet.pdf
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/unified-computing-system-adapters/datasheet-c78-741130.html
Hope this helps.
ksaanu12
What are the supported configurations for NVMe drives in UCS C-Series servers, and how does this technology impact storage performance and latency?
NVMe drives in UCS C-series servers can be configured in RAID, direct-attached disks or M.2 bootable options. It depends upon the drive type and purpose of the same to be used in deployment.
Refer to below white paper to understand the NVMe disk I/O characterization and how it impacts the storage performance:
https://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/ucs-c220-c240-m7-rack-server-wp.html
raramala
Hi Team,
What are the performance benefits of using the Cisco UCS C-Series for virtualized workloads in comparison to traditional blade servers?
amamulya
Can we mix M6 servers with previous-generation servers?
Hi Amulya,
Can you please elaborate on mix of M6 and previous generation?
If the query is about having M6 and other generation C series servers under the same UCS domain, then yes, we are able to have multiple types of generations under the same domain. Only consideration is hardware and software compatibility with the Fabric Interconnects and UCS Manager version.
If under Intersight, we can still have multiple generation of C series server be used simultaneously, as long as compatibility considerations are fulfilled.
Documentation :
UCSM Supported Hardware for 4.3 : https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/b_release-notes-ucsm-4_3.html#d54e2363a1635
Intersight Supported hardware : https://intersight.com/help/saas/supported_systems#supported_hardware_for_intersight_managed_mode
jaskiran-98
Can we manage U.2 NVME drives with Cisco 24G tri-mode RAID controller in C220-M7 servers?
The U.2 NVME drives are direct-managed in slot 1-4. The 24G tri-mode RAID controller only supports Drives SAS/SATA/U.3 NVME.
Refer below link for the same:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C240M7/install/b-cisco-c240-m7-install/m-storage-considerations.html
