How to boot-up Blade automatically upon power on?
steven.pw.lau
Is there a way to configure the UCS blades to boot up upon power on (assuming each blade already has a service profile associated)?
THanks.
bmoody
Steven,
When a blade is powered on that has a service profile associated it should boot based on the boot policy defined in the Service Profile. Once the blade is powered on you can monitor progress using the KVM console.
In UCS Manager under the Equipment tab if you highlight the server, then look on the right pane under Actions the Shutdown Server option will power
the blade off. The Boot Server option will power the server on.
Note that when configuring a Service Profile at the last step when you have the option to assign the profile to a server there is also an option to select the power state that should be applied to the blade when the profile is associated.
Bill
Well, I mean if let's say there's a power failure and then power is restored later, I want to have the blades being powered on automatically instead of going into UCSM manually to boot up the servers, upon restoration of power. Is this possible?
Thanks.
If you have firmware 1.3 you can create a BIOS Policy and link it to the service profile to configure the blade to auto power on if power is lost and then restored.
Got it...
Resume Ac On Power Loss under BIOS policy..
  • last-state—The server is powered on and the system attempts to restore its last state.
  • reset—The server is powered on and automatically reset.
If I choose reset, this means when the server is powered on, it'll be reset
However, I don't quite get what last-state means.
Is this referring to the last state the OS is in, it we didn't shutdown the OS, when the server is powered on, it'll load the OS at that last state? Doesn't make sense though.. Probably some examples would be good
Thanks..
