how to extend an existing raid 5 array- C220M3
walter baziuk
Level 5
Level 5
Hello
we have an existing UCS c220M3 server running as standalone
due to fiscal constraints at the time of order, we were only able to procure 4 HD for the server
we now wish to extend the raid array from 4 -> 8 HD.
we do not want to loose the existiong data or start from scratch
with EMC , Netapp and Qnap arrays, we can easily  extend an  existing volume.
I have searched cisco forms, support and google search with no luck
i only see references to the embedded MegaRaid controller or  the LSI MegaRAID external contoller
we have the CISCO UCS-RAIS-11-C220 hardware contolleron our c220 M3
any tips, guides  or links on how to do this would be appreciatted
walter
Keny Perez
Level 8
Level 8
Walter,
According to this guide:
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C220/install/raid.html
For the controller UCSC-RAID-11-C220 to support 8 HDDs, you need 2 mini-SAS cables (PID: UCSC-CABLE1)
If you go here: http://tools.cisco.com/squish/56bE6 < Expanding a Virtual Drive, you will later need to use an additional tool according to the OS you are running, to increase the size of the partition you had previously made.
See this document for more information
http://www.lsi.com/sep/Documents/oracle/files/SAS2_IR_User_Guide.pdf or look out for "Online Capacity Expansion", which is the name of this feature.
Hope this helps,
-Kenny
