Hyperflex Storage Controller VM wll not power on.
silviomanziano
Hyperflex storage controller VM will not power on.  Getting an error Module DevicePowerOn power on failed. Failed to start the virtual machine. Device 201:0.5 is not a passthrough device.  Has anyone ever seen this type of issue before.
Mark Elsen
 - Review these bug reports : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=Module%20DevicePowerOn%20power%20on%20failed&bt=custV&sb=anfr
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Unfortunately we tried this python script already from the ESXi server and it did not fix the problem.
message = 'Device 201:0.5 is not a passthrough device.'
(vmodl.LocalizableMessage) {
dynamicType = <unset>,
dynamicProperty = (vmodl.DynamicProperty) [],
key = 'msg.vmx.poweron.failed',
arg = (vmodl.KeyAnyValue) [],
message = 'Failed to start the virtual machine.'
reason = "Module 'DevicePowerOn' power on failed. "
Have seen similar issues a few times. Most often after a firmware upgrade renumbers PCI addresses or sometimes with failed hardware.
Does this server have NVMe disks? Just the NVMe cache disk or All-NVMe?
What do other servers show as "Device 201:0.5"? I usually edit another SCVM but do NOT make changes.
If the python script doesn't fix, then I'd check from that ESXi host what `lspci` shows and compare to other ESXi hosts.
Could be that a NVMe disk is dead, but really depends on the output of this server and what other servers shows.
Should probably open a TAC case and have TAC assist with the investigation.
