Java issues for CIMC KVM on C-Series
eric.fairfield
Level 4
Level 4
I am having troubles getting the KVM sessions going.  It is a Windows 7 workstation with Java 8 Update 25.  I have cleared the temporary files from Java.  I have added the server to the exception list so far.  Nothing seems to work.  I cannot lower security to medium as I have seen recommended as my control panel only has Very high or high, no medium.
The error is Unable to load resource https://x.x.x.x:443/software/avctNuova.jar
Reuben Farrelly
Level 3
Level 3
What version of CIMC code are you running?
I had this problem with earlier versions of CIMC, but 2.0(3)f3 seems to work just fine...
The constant cat-and-mouse game between Oracle and Cisco each "breaking" compatibility gets pretty tiring after a while though..
Woosang Cho
Try to downgrade your Java to Java 7 update 71(32bit).
I have solved the same problem with using Java version 7.
