KVM connection dropout
Networker_eg
Frequent Visitor
Frequent Visitor
whenever I start a KVM session it terminates with the below message :" Client has been shut down as a result of the network connection has been dropped. "
have anyone seen this before
Kirk J
Please make sure you have cleared your browser cache, or confirm you have tried from another workstation.
We see that message a lot after UCSM has been upgrade and browsers have old cached content.
Kirk...
Thanks Kirk ,
i tried it , did Not work , reset CIMC ip on service profile did not work neither  , I configured static ip on KVM and vola , works as a charm
So setting the same IP address, via static setting worked?
Kirk...
Setting a different ip worked and by the way , KVM access failed while HX installer was in the UCSM configuration stage with the message SOL access failed.
Also ,While expanding the Cluster with compute-only node , it failed to detect installed ESXi on the nodes , again configuring static KVM static ip solved the problem
before that I tried :
reset KVM did not work
rest CIMC did not work
disassociate / reassociate SP worked but  not practical in a production environment
Amr
