MDS 9124 and F Port Channels
hypnotoad
Level 3
Level 3
Hey all,
I'm trying to get my storage connected to my cool new UCS system. I have two MDS 9124 switche3s running 4.1(3a) code. My UCS system is running 2.03a. I'm running in FC End-Host mode.
I cannot get the port channel to come up. I found this thread that indicates that my 9124 switches don't support F ports in a channel config. Is this true?
https://supportforums.cisco.com/thread/2060353
Any help in getting these systems talking would be great.
Patrick
krun_shah
Looks like it does supports f port channeling but only with edge deployement see table 2 in below link of data sheet
http://www.cisco.com/en/US/prod/collateral/ps4159/ps6409/ps5987/ps7079/product_data_sheet0900aecd8057451f.html
Sent from Cisco Technical Support Android App
krun_shah
Looks like it does support f port channeling with npv switch like fabric interconnect see table 2 in below url.
Hello Patrick,
You need to upgrade NX-OS on MDS 9124  to support F port channel feature.
https://supportforums.cisco.com/docs/DOC-14838
Padma
Thanks for the document. It looks like I need to be at version 5.0(4). I like the typo in the doc that says NX-SO. Oops. I'll start on the upgrades and see if I can make it go.
