Nexus 5K VPC Consistency issue
chandanmajumdar
Issue : VPC consistency failed and VPC status is down on some of port channels wher as some other is working . This issue is for po18 only . once this is resolved will work on other Portchannels.
Topology,:
                        5k1                                   5k2
                          fex3                                 fex4
                                             server
Log for 5k3
5K3# sh run int e103/1/18
!Command: show running-config interface Ethernet103/1/18
!Time: Tue Dec 13 22:31:37 2011
version 5.0(3)N1(1b)
description *** Connected to GLARWI457-DATA1 ***
switchport access vlan 201
spanning-tree port type edge
channel-group 18 mode active
5K3#
5K3# sh run int po 18
!Command: show running-config interface port-channel18
!Time: Tue Dec 13 22:33:50 2011
description ***Connected to GLAWI457***
vpc 18
5K3# sh vpc brief
Legend:
               (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                       : primary
Number of vPCs configured       : 8
Peer Gateway                   : Disabled
Dual-active excluded VLANs     : -
Graceful Consistency Check     : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1   Po1   up     1-2,50-52,70-72,150,200-201,400,600,800
vPC status
id     Port       Status Consistency Reason                     Active vlans
4     Po4         down* failed     Consistency Check Not     -
                                     Performed
5     Po5         down* failed     Consistency Check Not     -
                                    Performed
10     Po10       up     success     success                   50-51,150,2
        00-201,400
11     Po11       up     success     success                   50-51,150,2
        00-201,400
12     Po12       up     success     success                   50-51,150,2
        00-201,400
13     Po13       up     success     success                   50-51,150,2
        00-201,400
18     Po18       down* success     success                   -
19     Po19        down* success     success                   -
GLASW-5K3# sh vpc consistency-parameters vpc 18
   Legend:
       Type 1 : vPC will be suspended in case of mismatch
Name                       Type Local Value           Peer Value
Shut Lan                   1     No                     No
STP Port Type               1     Default               Default
STP Port Guard             1     None                   None
STP MST Simulate PVST       1     Default               Default
Allowed VLANs               -     201                   201             (check this  local and peer vlan )
Local suspended VLANs       -     -                     -
GLASW-5K3#
GLASW-5K3#
Log for 5k4
5K4# sh run int eth 113/1/18
!Command: show running-config interface Ethernet113/1/18
!Time: Tue Dec 13 22:31:03 2011
description *** Connected to GLAWI457-DATA2 ***
5K4#
5K4# sh run int po 18
!Time: Tue Dec 13 22:34:09 2011
description ****Connected to GLAWI457***
vpc 18
5K4#
5K4# sh vpc brief
Legend:
vPC domain id                   : 1
vPC role                       : secondary
vPC status
                                     Performed
                                     Performed
        00-201,400
        00-201,400
        00-201,400
13     Po13       up     failed     Consistency Check Not     50-51,150,2
                                     Performed                  00-201,400
18     Po18       down* failed     Consistency Check Not     -
                                     Performed
19     Po19       down* failed     Consistency Check Not     -
                                     Performed
5K4# sh vpc consistency-parameters vpc 18
   Legend:
Shut Lan                   1     No                     No
Allowed VLANs               -     201                   1                   (check here local and peer vlan )
5K4#
5 Replies 5
clunsfor
Chandan,
What is the status of the physical interfaces and port-channel?  Do you see these as up if you do a `sh int` and `sh port-channel summary`?
Chris
Port channel and physical ports are down [line protocol down , configured and administratively UP] as the device is yet to be connectted by the DC engineer .
BUT For a different port channel [po 13 ] the portchannel , and physical interface and PO is up still the VPC is failing the consistency.
5K4# sh vpc brief
Legend:
vPC domain id                   : 1
vPC status
                                      Performed
                                      Performed
        00-201,400
        00-201,400
        00-201,400
18     Po18        up     success     success                    201
19     Po19        up     success     success                    201
5K4# sh int po 13
port-channel13 is up
vPC Status: Down, vPC number: 13 [packets forwarded via vPC peer-link]
  Hardware: Port-Channel, address: 0007.7dc9.fc4f (bia 0007.7dc9.fc4f)
  Description: "Connected to GLAVM403"
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 1000 Mb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is on
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth113/1/13, Eth113/1/14
  30 seconds input rate 106976 bits/sec, 13372 bytes/sec, 54 packets/sec
  30 seconds output rate 2132520 bits/sec, 266565 bytes/sec, 561 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 173.32 Kbps, 36 pps; output rate 2.44 Mbps, 419 pps
  RX
    403285418 unicast packets  171096 multicast packets  161845 broadcast packets
    403618359 input packets  275739294703 bytes
    138861776 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    1612098077 unicast packets  186946046 multicast packets  117268953 broadcast packets
    1916313076 output packets  947767205968 bytes
    431627748 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  5 interface resets
5K4# sh port-c summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      LACP      Eth4/15(P)   Eth4/16(P)
4     Po4(SD)     Eth      LACP      Eth4/13(I)
5     Po5(SD)     Eth      NONE      Eth4/14(D)
10    Po10(SU)    Eth      NONE      Eth113/1/33(P)  Eth113/1/34(P)
11    Po11(SU)    Eth      NONE      Eth113/1/26(P)  Eth113/1/27(P)
12    Po12(SU)    Eth      NONE      Eth113/1/8(P)  Eth113/1/9(P)
13    Po13(SU)    Eth      NONE      Eth113/1/13(P)  Eth113/1/14(P)
18    Po18(SU)    Eth      LACP      Eth113/1/18(P)
19    Po19(SU)    Eth      LACP      Eth113/1/19(P)
112   Po112(SU)   Eth      NONE      Eth4/1(P)    Eth4/2(P)
113   Po113(SU)   Eth      NONE      Eth4/3(P)    Eth4/4(D)
GLASW-5K4#
5K4# sh vpc consistency-parameters vpc 13
    Legend:
Shut Lan                    1     No                     No
mode                        1     -                      on
Speed                       1     -                      1000 Mb/s
Duplex                      1     -                      full
Port Mode                   1     -                      trunk
Native Vlan                 1     -                      1
MTU                         1     -                      1500
Admin port mode             1     -
Allowed VLANs               -     50-51,150,200-201,400  50-51,150,200-201,400
GLASW-5K4#
As you've probably seen now, until you have operational members in the port-channels, you'll see the vpc as failed and "consistency check not performed" on one of the switches.
Interestingly, the vpc consistency parameters are missing the local values for 5K4.  Have you tried doing a shut/no shut of po13 on 5K4, or removing and re-adding the vpc command to the port-channel?
jkilleda
Level 3
Level 3
Hello Chandan,
I had faced the same issue as VPC status down , I reconfigured VPC and it worked.
